Fighting a bog
Old Aug 18, 2016 | 12:13 PM
mountain dewd's Avatar
mountain dewd
Fighting a bog
Hi folks, I have been driving my truck a bunch lately, and that has given me the opportunity to have to get on the gas while at speed. The truck drives great, has lots of power and cruises nicely, but at 60 or so mph, it bogs for an instant if I apply lots of throttle briskly. It still pulls hard. I put in a new accelerator pump that only helped marginally. Any ideas? Thanks!
Old Aug 18, 2016 | 05:03 PM
RileyCarroll's Avatar
RileyCarroll
Subscribing to learn, mine does that at all speeds
Old Aug 18, 2016 | 05:27 PM
tabascom16's Avatar
tabascom16
Is it a Holley? If it is then it will also have an accelerator pump cam (maybe 2 if mechanical secondary 4 barrel). You can buy different cams and also adjust each cam to typically 2 different settings, some designs having a 3rd.
They can make a rather significant difference as I have toyed around with them in the past. The cam determines how far the accelerator pump is pushed in relation to the amount of gas pedal movement.
It could be other things but I would probably try and mess around with this first.
Old Aug 18, 2016 | 07:56 PM
mountain dewd
Thanks for the reply. If you look in my sig, you will see that it is an Edelbrock.
Old Aug 18, 2016 | 08:47 PM
tabascom16's Avatar
tabascom16
Hesitation or Bog? - JGronoJ
Old Aug 19, 2016 | 09:18 PM
mountain dewd
Thanks a bunch!
allwthrrider
Feb 1, 2012 12:25 AM
crazyeddie
15
Oct 29, 2009 06:03 PM
nairod
Jun 19, 2009 09:18 PM
jerryh20
Jan 9, 2007 06:27 PM
78broncoman
Sep 24, 2004 08:32 AM
