What do yall think?
Old Sep 24, 2004 | 01:52 AM
78broncoman's Avatar
78broncoman
What do yall think?
I'm finally on the final stages of my 390 rebuild and Im gonna be putting a holley 600cfm double pumper on it with the stock RV cam and long tube headers. it is going into a 74 highboy what do you guys think of this combo?
thanks
Old Sep 24, 2004 | 02:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
I don't like using a double pumper on a street vehicle. I prefer vac secondaries for that application.
-Just my 2 cents
Old Sep 24, 2004 | 03:54 AM
averagef250's Avatar
averagef250
Double pumper and heavy vehicle is a bad combination. I'd go with the old standard holley 1850. Double pumper's have two accelerator pumps vice one and machanical secondaries. You need a big cam that does not make much low end power to run one. I've seen a double pumper holley work on lightweight off road rig with a mild 351w, but believe the only reason they worked was the weight of the vehicle. If you need more accelerator pump you can always change the pump cam and even change the pump size up to 50CC. You need a very nasty cam profile to handle a 50cc pump.
Old Sep 24, 2004 | 08:32 AM
FORD352V8's Avatar
FORD352V8
doubel pumpers are not streetable they are a PAIN. Just get a vacum seconadary it will work BETTER for your application then a double pumper.
