Well I have the dreaded coolant leak under my intake and have been looking for a new intake manifold. My Expy is a 1998 with a 5.4 and a all aluminum manifold. My question is does this intake fail like the plastic ones and second the only one I can find for the 5.4 is $400.00. The ones for the 4.6 are half that amount. Will the one for a 4.6 fit on the 5.4?
It might just be the heater tube and not the intake. You can buy a new tube or you can repair it with heater hose and a couple of hose clamps.
It turned out to be the metal pipe that runs under the manifold but while I was taking off the intake I didn't realize there where two bolts way at the back by the fire wall and I ended up snapping off the ears on the manifold so I had too replace the intake with a junk yard one. She is up and running and runs really good. I also did plugs, boots and the PCV boot on the back of the manifold..Next up front heater core which could be just a daunting..
