Observations About Gear Ratio Differences
Old Sep 6, 2016 | 06:29 PM
  #31
Gary Lewis's Avatar
Gary Lewis
Ok, here are the final MPG results. Basically we got 11.0 MPG for the whole trip, which is good in my opinion. But, I'd like to point out a significant difference. The 1st and last legs covered much the same ground and there's not enough elevation change to make much difference. In fact, on the last leg the boat was ~250 lbs heavier and we had significant side winds. But the 1st leg got 10.02 and the last got 11.26 MPG. Why? I believe it was in the fuel - 89 vs 91 octane.
Old Sep 7, 2016 | 08:55 AM
  #32
GlueGuy's Avatar
GlueGuy
Great report Gary! I might argue that a cross wind is almost the same as no wind, unless it's a quartering head-wind. None-the-less, this is an excellent bench mark to compare with our own rigs.
Thanks a bunch.
Old Sep 7, 2016 | 11:07 AM
  #33
Gary Lewis's Avatar
Gary Lewis
Thanks. I hope it answers a few questions, such as the effect of octane and altitude. Octane has a big effect and altitude doesn't, at least on the power output. I couldn't tell a bit of difference at 7000' vs 700'.
But I disagree on the wind. As the wind came up during the day I could see the MPG edge down. And I could feel the extra drag. Remember, I was babying it and not using cruise, so I could tell even minute differences. Plus I was monitoring boost, and could see it trending up as the wind came up.
Old Sep 7, 2016 | 05:04 PM
  #34
GlueGuy's Avatar
GlueGuy
I think you said somewhere in there that you were doing ~~ 65 MPH for most of the trip? In CA, vehicles pulling a trailer are limited to 55 MPH, (except where posted). Kind of an antiquated law, but it is what it is. I'm wondering if our mileage will be quite different at that speed? I actually run closer to 60 MPH, and the CHP seems to be quite lax on enforcing the law, but I don't like to push my luck. I haven't gotten a ticket in about 40 years or so...
Old Sep 7, 2016 | 05:07 PM
  #35
Gary Lewis's Avatar
Gary Lewis
Yes, I ran 65 MPH. I don't know what other states have as laws, but 65 was slow enough as we were passed many, many times by 18-wheelers going far faster than that.
But your MPG should be better at the slower speeds.
Old Sep 7, 2016 | 05:21 PM
  #36
GlueGuy's Avatar
GlueGuy
Actually, CA limits both vehicles pulling trailers AND big rigs to 55 MPH. So my clue about what speed is "acceptable" in a particular area is influenced by what the 18-wheelers are actually doing. If they're going 70, then the hammer can go down.
Old Sep 7, 2016 | 09:21 PM
  #37
seventyseven250's Avatar
seventyseven250
Well, drag is basically frontal area (or drag coefficient) times the square of the speed, so yes, slowing down will have a much bigger effect when towing than when not towing.
DLTtoday
2009 - 2014 F150
25
Sep 10, 2013 11:52 AM
ctownson
6.7L Power Stroke Diesel
Apr 27, 2010 09:03 PM
78bigbronco
3.8 & 4.2L V6
Jun 18, 2008 11:23 PM
Thudpucker
1997 - 2003 F150
Apr 4, 2006 11:50 PM
hoxiii
Mar 21, 2005 07:48 AM
