Setting Idle
Old Aug 16, 2016 | 03:36 PM
hharris8's Avatar
hharris8
Setting Idle
Now that I have everything installed I need to set idle on the carb. What are my steps here?
1986 Ford Bronco with '79 LTD II 8 cylinder 302 engine. Edelbrock Performer 500 cfm electric choke carburetor with Edelbrock performer 2121 intake manifold.
Old Aug 16, 2016 | 04:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What is the idle speed stated on the compliance sticker on the radiator support?
Automatic is usually in gear.
Manual in neutral.
Set the parking brake and chock the wheels.
I used to do automatics up against a concrete retaining wall.
Fully warm up the engine (like a 20 minute drive)
Remove the air cleaner and adjust the throttle stop.
If you really want to get into it, you would then adjust idle mixture for highest vacuum and then reset curb idle.
Back and forth until it wouldn't change, and then open the screws 1/8 turn and confirm the speed again.
Old Aug 16, 2016 | 04:07 PM
hharris8's Avatar
hharris8
Thanks. I will give it a try.
Old Aug 17, 2016 | 01:54 PM
hharris8's Avatar
hharris8
I turned the mixture screws one at a time watching the RPM's (which fluctuate by about 15-20 at idle) and periodically adjusting idle speed and when it hit max RPM before going back down I stopped and did the other screw the same way. When it was at max RPM I then screwed them back flush counting the turns and backing them back out the same amount. They are backed out 2 5/8 turns out. Is that about right?
Do not know if this has anything to do with it, but the cam was replaced by previous owner and I found the receipt today. I will get back on what size and brand it is.
thedopefishlives
Mar 17, 2017 05:31 PM
Codeseven
Jan 20, 2017 06:29 PM
gcarson5135
Aug 9, 2014 09:32 AM
jjurva
Oct 26, 2011 09:06 PM
bluesky636
Aug 24, 2004 10:52 PM
