1978 - 1996 Big Bronco
Vibration while running
Old Aug 16, 2016 | 02:58 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Ok so we have a 95 Bronco 4x4 5.8L E4OD that is giving us some issues.
When idling we get a slight vibration not to bad but enough that I can notice it whether in gear or not. As soon as you start driving it smooths out but still a slight vibration almost not noticeable no cel at this time. As soon as you get to 35-45 mph you can really feel a bad vibration (this is when the CEL comes on again) then you start getting to 50+ mph and it starts to smooth out again.
When you slowly accelerate there is a slight hesitation but you punch it and it takes off like a bat out of hell.
I pulled the codes and only code is a 332 while running. It passes key on engine off.
When you key on engine off fuel pressure the fuel pressure goes up but not all the way to spec about 2 psi to low you start the engine then it goes to spec. You then shut off and drop off is about normal.
When you relive the pressure and do a Key on engine off again the fuel pressure is within spec.
Reving up it goes up to spec also.
It has a brand new fuel pump, new gas cap, fuel filter, fuel pressure regulator, and lines have been blown out. It also has new wires, plugs(NGK which I may change out as I never liked them they came with the truck), new cap and rotor, pcv valve, and air filter.
I have also seafoamed the fuel system. everything that I have done has helped it a little bit but not cured the issue.
not sure if it matters but the coolant temp gauge is not working. Also the transmission is a reman that has an upgraded valve body but I highly doubt that is an issue it shifts with no issues at all actually one of the best shifting of all my auto trucks.
I checked and it is running on all 8 cyls.
It starts with almost no hesistation. It actually starts better then my dad's 91 bronco 5.8L.
I haven't checked timing yet. I am wondering if it is possibly a vacuum issue?
If not what could be causing this?
Trav
Old Aug 16, 2016 | 04:07 PM
Kemicalburns's Avatar
Kemicalburns
motorcraft copper plugs for sure. Make sure the plug wires are routed and not touching each other best you can. Timing should be 10*btdc with spout connector removed. you need to figure out why the temp gauge isnt working. the computer expects to see a minimum of 195* for proper fuel mixture/delivery.
Old Aug 16, 2016 | 04:30 PM
Encho's Avatar
Encho
The Southernmost Mod
^ definitely my suspect, those sparkplugs.
Old Aug 17, 2016 | 01:22 AM
Redneckfordf2502002
I run autolites usually so I will probably switch out for them.
Plug wires are routed so none are touching I ran into that issue with my 88 getting crossfire.
I am guessing either the sender or gauge is bad. The sensor doesn't talk to the cluster right?
will check timing before all also.
Trav
Brentburek
Jan 28, 2020 09:26 PM
mrjustice1324
96
Aug 3, 2018 10:12 AM
TheKirbyMan
Apr 23, 2016 05:13 PM
90fordguyohio
Dec 19, 2010 08:00 AM
dgiusti
13
Mar 22, 2008 09:27 PM
