Starting problems
Old Mar 30, 2004 | 08:40 PM
  #31
fordtruckfan90's Avatar
fordtruckfan90
Try a fuel pressure regulator, from the symptoms you mentioned, its fairly cheap and easy to do!
Old Apr 4, 2004 | 12:00 PM
  #32
couleeman's Avatar
couleeman
Originally Posted by couleeman
It has seemed to do the trick (fuel pressure regulator). I just don't want to post to soon and then have the problem arise again because I didn't get to drive it enough and test it out. I will post by the end of the week to confirm it solved the problem. The old fuel pressure regulator was bad though.
The fuel pressure regulator made a difference, but the problem is still there. Not sure what to try next. I am thinking I am going to try the fuel pump next, but will wait a bit as I want to put a bigger tank on at the same time.
jjautos
16
Jan 8, 2017 02:16 PM
Gary Henderson
Jun 26, 2016 01:54 PM
9rudy9
Feb 1, 2016 10:46 AM
jolinberg
Bronco II
Apr 23, 2013 04:48 PM
lillbro11
19
Jul 22, 2009 03:04 PM
