knock sense again
Old Aug 19, 2003 | 07:35 PM
lwpman's Avatar
lwpman
knock sense again
Does anyone know is it ok to unplug the sensor and drive it that way????
Old Aug 19, 2003 | 09:57 PM
serving_time's Avatar
serving_time
knock sense again
Why would you?
Old Aug 19, 2003 | 10:35 PM
bassguy31's Avatar
bassguy31
knock sense again
My truck has a little bit of valve pinging on take-off and oil blow-by which shows up as an oil spot on my air filters. I am assuming that it's worn valve guides. I did unplug my knock sensor and the truck will run without it, but it does ping more (which is not a good thing). If you're having a problem with pinging, I would retard the timing or go to a higher octane fuel. If you really want the problem solved, it means tearing into the motor.
Old Sep 7, 2003 | 08:44 PM
abock33's Avatar
abock33
knock sense again
if you unplug it the engine will run rough because the ECM uses it for engine timing.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
