Rear View Mirror Placement
Old Aug 12, 2016 | 08:42 PM
Hubba56's Avatar
Hubba56
Had to get a rear view mirror for my 73 F100. Can someone measure theirs for the placement on the windshield. Like centered, how many inches from the top of the windshield?
TIA
Old Aug 13, 2016 | 10:32 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
One truck 3" other truck 3 1/2" down, measured on the outside from the bottom of the windshield seam. 32" from the outside seam edge to edge of mount piece.
Old Aug 13, 2016 | 10:46 AM
Jklnhyd's Avatar
Jklnhyd
Since you are probably buying an aftermarket mirror, this is what I would do, because I ran into this before.
Put your sun visors down, then find the center line between them. Hold the mirror about 3" down, and see if you can still flip the visors up, and unclip them and swing them to the sides.
Old Aug 13, 2016 | 12:13 PM
tbear853's Avatar
tbear853
Mine fell off about 25-30 years ago, I took a piece of about 11 gage steel same width as mirror base at widest point .... long enough to sandwich under the center sun visor clip and drop down to where I wanted the mirror mounted which in my case, was not far. Always thought mirror was too low. Mounted "button" to steel with glue or epoxy and a single counter sunk screw through center, painted, mount between that plastic visor clip and metal body with two holes drilled in plate to match, never again fell off.
Old Aug 15, 2016 | 08:37 PM
Hubba56's Avatar
Hubba56
Thanks guys.... Fit perfectly
Old Sep 18, 2016 | 07:54 AM
Damifiknow's Avatar
Damifiknow
Anybody put on an older mirror from like a 57-60 truck that mounts to cab above the windshield? Mine fell of yesterday and I have never had any luck with the glue to put it back on.
tbear853? How about a picture of what you did?
eclectix
13
Feb 9, 2017 05:44 PM
zakt
WTB - Parts & other
Jun 19, 2011 02:21 PM
perryg114
Oct 21, 2010 08:07 AM
jpill
Oct 7, 2008 04:38 PM
Munkey
General Automotive Discussion
Sep 18, 2004 09:41 AM
