EFI = Electronic Fuel Injection . It basically just says that the fuel delivery system uses electronically controlled fuel injectors . Surely you got more of a cause of the no start problem than that . That explanation is like saying its dark at night . Call over to the Ford Dealer & ask to speak to the mechanic that is working on your truck & have him explain whats going on with your truck .
>Ford says EFI needs to be replaced, what is efi?
>Thanks,
>Bill
I am the owner of a 1991 Ford F150 Conversion Van (Universal - Glaval) it wont start either. I am looking for the fuel reset button - it is not located as indicated in the owners guide. Can you tell me where it is located please.
I would look up on the inside cab firewall where the clutch pedel would be if it had one. Also near the hump on passenger side hidden by carpet or mat.
