Brake light help
Old Nov 16, 2003 | 05:30 PM
Metalgod1919's Avatar
Metalgod1919
Question Brake light help
i have a '70 F250 360 with a 750cfm edelbrock preformer
well anyway my problem is that the brake lights won't work
i've checked the wires and they seem to be ok but i don't know (the guy who had it before me went redneck joe on the wiring harness).
it is not the bulbs
i'm thinking i need to buy a new switch and re run the wires
does anybody know if i can purchase a switch for this truck or wil i have to find one somewhere else
ps any ideas on fixing this prob. an easier way would be greatly appreciated. thanx
Old Nov 16, 2003 | 05:36 PM
stepman's Avatar
stepman
Do you have a test lihght or meter? Check for power at the switch. Check both sides with pedal pushed and released.
Old Nov 16, 2003 | 05:39 PM
Metalgod1919
i have i light i just can't get into the right spot to test it
i will have to give it a try
thanx
btw do u have any clue as to the polarity on the switch??
Old Nov 16, 2003 | 05:48 PM
orich's Avatar
orich
Did you remove the wires from the switch and run a jumper wire from wire to wire and see if they come on? If not any lights, then put a test light one wire and grounded to see if you have 12 volts ? If not then check the fuse
Old Nov 16, 2003 | 08:13 PM
Faithful Old Road Dog's Avatar
When my brake lights went out, I checked the bulbs, but they were good. I then checked for juice at the socket with the brake pedal depressed. That's when I noticed that the sockets were pretty crusty. I took a 1/2" copper pipe sweating brush and cleaned the inside of the sockets. That did the trick.
Old Nov 16, 2003 | 08:26 PM
orich's Avatar
orich
I thought you may have done that first. Oh, I had that happen also once, a shot of W-D40 has been good for about 10 yrs now.
Old Nov 17, 2003 | 04:09 PM
Opiewan's Avatar
Opiewan
my problem on my 70 was the wires coming from the turn signal , after i pulled my steering wheel off and redid the wiring i had brake lights again also blinkers. i still have one on the drivers side not working right but i think thats just a ground problem. because if it works on one side it should work on the other unless your wires in the back are a mess like mine was, seems the orignal owner wanted to haul a trailer and instead of getting a plug and wiring it right he just sliced all the wires and used tape to hold them togather, took three hours with shrink wrap and a soldering iron to get it right again.
