6.2L V8 Discuss the 6.2L V8
Engine Cooling System
Old Aug 9, 2016 | 02:00 AM
WK57ABF's Avatar
WK57ABF
Can someone help please.
What are the flimsy plastic shrouds attached to the radiator sides called? The two on my truck are torn & damaged and coming away from the plastic push pins that hold them in place.
Is it ok to remove them completely or will doing that have an effect on engine cooling?
Truck is a 2014 Super Duty 6.2 CCLB.
Thanks, John in the UK
Old Aug 9, 2016 | 07:32 AM
RightWingNutJob's Avatar
RightWingNutJob
They're called "Radiator Air Deflectors"
They help channel air into radiator - you probably won't miss them for most driving conditions, but if you're towing or hauling heavy on a hot day they probably do make a difference in your operating temperatures.
Here's a link to a U.S. Ford part site - there's several deflectors listed.
http://www.fordparts.com/Commerce/Ca...er Duty#Search
Old Aug 9, 2016 | 08:00 AM
LakelandFordParts's Avatar
LakelandFordParts
Former Vendor
As RightWing said they are called radiator air deflectors. It looks like the part numbers are BC3Z8311A for the LH/drivers side and BC3Z8310A for the RH/passengers side. I hope that helps out.
Old Aug 9, 2016 | 12:52 PM
WK57ABF's Avatar
WK57ABF
Thanks for your replies WingNut and Lakeland.
I will remove the damaged deflectors and will monitor engine coolant temperature via dash command. I am reluctant to replace as the material used to manufacture them seems of poor quality and not up to the job.
It's summer here in the UK - 6l-63 degrees this week, so no problem with hot weather and our travel trailer is only 8000 lbs.
John in the UK
Old Aug 9, 2016 | 06:19 PM
Unclemark's Avatar
Unclemark
Mine were torn ffom the factory...
Warhawk77
13
Sep 18, 2017 10:17 AM
EXv10
Sep 23, 2012 11:29 PM
LARIAT 85
22
Apr 1, 2012 09:21 PM
89ranger2.9
Apr 22, 2007 08:39 PM
JoeVB
Dec 31, 2005 06:29 PM
