`06 F250 6.0 Error codes
Okey, lets start with a short storey: I bought my truck 2 month ago. I use it for commuting, only short trips now ( 10 min ).
After about 2 weeks the Check Engine light came on. The truck is running fine, no problems I believe, starts easy. After another 2 weeks, the CEL disappeared. Another week, and the CEL came back on and it`s there since.
I have a code reader, these are the codes and meanings according the manual:
P0299 - Turbocharger "A" underboost condition
P2286 - Injector control pressure sensor circuit high
P2287 - Injector control pressure sensor circuit intermittent
P0299 Pending - same as first but with "pending" status
This is my first diesel and my first turbo charged engine. Is this a common problem? How serious?
It`s a bit strange that the error came up before but disappeared. Can that happen just because of the short trips I`m making?
I`m planning a long trip soon with towing my trailer, so I want to make sure the truck will not break down during the ride.
Hope you can help me
I have a feeling that this happens because of the short trips I`m making so I deleted the codes. Tomorrow morning I will take the truck for a long drive. There is a nice lake about 1 hour from our place, so I take my girlfriend to make her happy
So I will have 2 X 1 hour drive, which should clear out the system and exhaust. If the code comes back qiuck, than I will take the truck to the service and change the ICP sensor. I have an appointment already for the 19th ( that was the earliest they had ).
If the codes do not come back during this time, than it only needed a longer ride. We will see.
By the way it is a 2006 F250 4x4 with 150.000 kms ( so less than 100k miles ).
here is a good video by Ron -
I deleted the codes from the computer the other day. I took the truck for a long drive ( bit more than 1 hour, highway and offroad mix ). Than it was shut down for about 1 hour and I took the same road back. Since than, I took 2 short trips. No CEL light yet.
Actually on the way back on the highway I had the wrench light came on, which never happened before. That is a totally different issue, and hopefully it was only because I pushed it hard the way back, harder than I will ever ride it.
The truck will sit for 2 days, and than I have to do some short trips again. Hopefully the CEL does not come back. Fingers crossed
My problem is that we have speed limits here as low as 40-50 km/h, which means if I hit the throttle hard, I`m over the limit in a few seconds. Right now all I can do is to take my baby out to the highway and ride it for 1 hour, but it is pure money burning. My situation will change withinin a month or two hopefully. If it does, than I have to make a 5000km trip with towing my trailer, which will give the old lady a good workout for sure. After that I will have longer rides, only a few short trips, so we only have to survive for a bit more
Hopefully the cooling system will manage the towing ( remember, I had the wrench light coming up the other day ), otherwise I will be in a trouble. The next town is 500km away ( nothing inbetween ), so the first section is crucial. Well, the second section is even longer, but if there is a problem, than I`m sure it will come out on the first day.
The ICP sensor has probably an oil flooded connection. Check it, it's in the passenger valve cover.
Ofc this only works if the problem was minor. If I have bigger problem, than the system cannot clean out itself and it needs to be done by a mechanic ( I cannot do a repair job like this now ).
I`m happy to pay for the repair, but even the mechanic told me to try this first and see what happens. This is where I am now. Haven`t used the truck for 2 days, and now I have to do 2 short trips for 4 days. If the code comes back, than use my appointment on the 19th. If the code does not come back until the 18th, than I will cancel my appointment.
It looks like that the 2 * 1 hour drive on the highway solved my problem. Deleted the error codes before I took her on the ride, and the codes are not back since, which is good, because I use the truck daily for only short trips now ( 10 min ).
I don`t know what the problem was, maybe the turbo was a bit stuck inside, but the baby is working nice, no problems at all. I`m happy
Will take her on a long trip soon ( 5k km towing my 20` enclosed trailer, only about 600km / day ), hopefully she can do that easy.
When running empty if you see a hill slow down
and then punch it and then back off.
When I go to the post office less than 2 miles away I
come back the long way. that adds about 10 to 15 miles to the trip.
If you don't work that turbo hard it will stick and give you grief.
There is no real way around it you need to dive this and it just part
of the care and feeding of a turbo diesel engine.
Sean <BR>
6.0L Tech Folder
It looks like that works.
It also covers turbo issues. Look for this code
Turbocharger over boost detection - DTC P0234 stored and wrench warning lamp
illuminated when a turbocharger over boost condition occurs.
BTW full operating temp is 192ºF ECT some run a little hotter.
If your going to short trip the truck then you will also want to change the oil sooner.
This is do to condensation in the engine from heating and cooling, That moisture will
combine with combustion byproducts and create an acid that will attack the metal
internals of the engine. There are steps to take to work around this. I'll post more after
I have a little sleep.
Sean <BR>
6.0L Tech Folder
