Problem with intermittent wipers
Old Aug 8, 2016 | 07:11 PM
LipschitzWrath's Avatar
LipschitzWrath
Need some help guys.
I have a 1978 Ford F250 I am restoring. It's an honest to god Ranger XLT but it didn't come with intermittent wipers. So I jumped on ebay and bought a used setup that included the control box and switch.
I finally wired it up and I don't have low-speed or intermittent (I am guessing intermittent uses the low-speed, so I believe they are related). High speed works fine. The motor is also okay because if I manually apply 12 volts to the white wire, the motor runs fine in low speed.
If I put it in low speed - nothing. If I put it in high speed and then while the wiper is mid position switch it to low, the wiper stops. If I switch from high to intermittent, the wiper will return to park, but won't go further.
Now, I'm sure this isn't the first documented case where someone sold something on ebay that was broken without admitting that, but how do I determine if it is the switch or control box? Any tests I can run? I no longer have the original 2-speed switch.
The wiring on the control box is different colors and I dunno if a simple continuity test from +12V to low speed is sufficient.
Can anyone lend any help>
Old Aug 8, 2016 | 07:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Two questions, are you using the correct intermittent switch (turns counterclockwise past off to set the delay) and is it installed in the dash?
The switch must be grounded for the intermittent part to work and it grounds through the metal dash.
Old Aug 8, 2016 | 07:28 PM
LipschitzWrath
Yes to both.
Old Aug 8, 2016 | 09:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you seen this? http://api.viglink.com/api/click?for...%20-%20YouTube
Twodifferenttypesof windshield wipers, twodifferentwiperswitches. Two speed wiper switches have alow&high speed.
Intermittent(delay) wipers were optional on 1973/79 F100/350's and 1978/79Bronco's. Intermittent isnotanothername for low speed!
DOOZ-17A553-A..Two Speed Wiper Switch-Notusedwith intermittent wipers (MotorcraftSW-896)/ Marked:D0OB-17A553-AorD/Obsolete
1973/79F100/350 / 1978/79 Bronco // 1970/71 Fairlane/Torino/Montego /1970/72 Maverick/Comet.
SUSANVILLEFORD in Susanville CA=530-257-2137.
NOSONLY in San Jose CA =800-667-6659.
WESLEYOBSOLETE PARTS in Liberty KY=606-787-5293.
GREENSALES CO. in Cincinnati OH=800-543-4959.
D1OZ-17A553-A..Two Speed Wiper Switch-Usedwithintermittentwipers (MotorcraftSW-1010)/ Marked:D1OB-17A553-AA/Obsolete
1973/79F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
NOSONLY
BURNSFORD in Burns OR=541-573-7278.
GREENSALES CO.
AndD1OZ-17A553-A..Two Speed Wiper Switch-Used with intermittent wipers(MotorcraftSW-1010)/ Marked: D1OB-17A553-AA / Obsolete DON'STRUCK SALES in Fairbank IA= 319-365-2751.
MCDONALDOBSOLETE PARTS CO. in Rockport IN= 812-359-4965.
WESLEYOBSOLETE PARTS in Liberty KY= 606-787-5293.
GREENSALES CO. in Cincinnati OH= 800-543-4959.
CARPENTERNOSOBSOLETEPARTSin Concord NC=800-476-9653.
Thereare TWO different intermittent wiper governors. 1973/77 is one type,1978/79 is another.
D3TZ-17C476-A(replacedD1ZZ-17C476-A) Intermittent Wiper Governor / Obsolete
Old Aug 8, 2016 | 09:26 PM
ultraranger's Avatar
ultraranger
Most likely there are some bad solder joints on the circuit board. In most cases, it's a simple matter of resoldering the joints to restore normal function of the wiper governor module.
Old Aug 8, 2016 | 10:33 PM
LipschitzWrath
NOSONLY
GREENSALES CO.
I most definitely have the intermittent wiper switch with ground lead and accompanying governor module. After watching the video and comparing, it appears I have an 80's model. The video led me to believe this isn't a problem and should be a direct swap - correct?
How hard is that? Will it be obvious what I need to solder? How do I open the module?
Okay, now two questions of my own. First, if it is indeed a poor solder joint like suggested above, would that cause low speed AND intermittent to fail?
Second, if I were to just bypass the governor module altogether and hook my switch directly to the truck wiring (like non-intermittent trucks, but using an intermittent switch), what would happen?
Because I did already, and nothing changes. Low speed still doesn't work.
Old Aug 8, 2016 | 10:46 PM
ultraranger
The Ford truck delay wiper governor modules are pretty much the same THROUGH 1991.
https://www.ford-trucks.com/forums/1...l#post15809003
Old Aug 9, 2016 | 11:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two different types of windshield wipers, two different wiper switches. Two speed wiper switches have a low & high speed.
Intermittent (delay) wipers were optional on 1973/79 F100/350's and 1978/79 Bronco's. Intermittent is not another name for low speed!
D0OZ-17A553-A .. Two Speed Wiper Switch-Not used with intermittent wipers (Motorcraft SW-896) / Marked: D0OB-17A553-A or D / Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1970/71 Fairlane/Torino/Montego / 1970/72 Maverick/Comet.
SUSANVILLE FORD in Susanville CA has 0.
NOS ONLY in San Jose CA = No longer in business.
WESLEY OBSOLETE PARTS in Liberty KY = No longer in business.
GREEN SALES CO. in Cincinnati OH has 0.
PARKS AUTO PARTS in Charleston SC has 3 = 843-744-0527.
VINTAGE PARTS INC in Beaver Dam WI has 488 = 877-846-8243.
D1OZ-17A553-A ..Two Speed Wiper Switch-Used with intermittent wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
BURNS FORD in Burns OR has 0.
DON'S TRUCK SALES in Fairbank IA has 1 = 319-365-2751.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 10 = 800-476-9653.
There are TWO different intermittent wiper governors. 1973/77 is one type, 1978/79 is another.
D3TZ-17C476-A (replaced D1ZZ-17C476-A) .. Intermittent Wiper Governor / Obsolete
1971/73 Mustang/Cougar / 1973/77 F100/350.
No Ford dealer or obsolete parts vendor has any.
D8TZ-17C476-A .. Intermittent Wiper Governor / Obsolete
1978/79 F100/350 & Bronco.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Information updated 8/9/2016.
Old Aug 9, 2016 | 12:41 PM
77&79F250's Avatar
77&79F250
Thank you for the update.
Old Aug 9, 2016 | 04:13 PM
LipschitzWrath
Thanks all for the help.
I opened the governor box up and had 3 cracked solder joints. I fixed those and everything is functioning as it should. Thanks.
Old Aug 9, 2016 | 05:46 PM
ultraranger
Simple, easy fix and now you're back in business.
wpnaes
S. California Chapter
57
Apr 28, 2021 02:33 PM
CelticOne
WTB - Parts & other
Jan 19, 2017 10:25 PM
Chris Popanz
Nov 26, 2015 03:09 PM
Zip
British Columbia
Sep 30, 2008 02:10 AM
SuperSnake
North Carolina Chapter
Sep 21, 2006 10:46 PM
