2016 Payload versus 2017 Payload
Old Aug 10, 2016 | 03:59 PM
2009kr's Avatar
2009kr
I think the bottom line is they saved ~200 lbs using the aluminum - the chassis upgrades. The extra fuel drops the payload increase to 120# on the CREW 6.7 short bed and the increase is 70# on the CREW 6.7 long bed. I'm sure all of the goodies on the Platinum ultimate will make up the 70# difference --> same payload for 2017 as I'd have in a 2016. I'm more confident it will be OK over the GVWR than the 2016 though as long as I'm within the GAWRs.
Old Aug 11, 2016 | 05:35 PM
2009kr's Avatar
2009kr
BTW, I realized that the 110# RAWR bump for srw mainly helps those with the 6.2. With the 6.7, you have 5100 lbs on the front axle, 5300-5600 lbs when you have passengers. With the old 7120# axle, you'd gross well over 12k before approaching the limit.
I figure I'll have 5600# on the front with 5 people + dog in the cab. To hit 7230# on the rear axle, I'd have 12830# (1330# over my GVWR) on my wheels. With the 750# lighter 6.2, you can approach the axle limit without blowing through the GVWR so bad.
Old Aug 16, 2016 | 02:50 PM
ripstertx's Avatar
ripstertx
Payload Document for F-250 - F-550
https://www.fleet.ford.com/truckbbas...017/specs.html
2017 F-Series Super Duty Supplemental Order Guide
has payloads by model, cab type, bed, bed-delete and cab and chassis across all F-Series including through the F-550 and it breaks the payload down by engine type as well as GVWR. Next? Maybe they'll do the same for Tow Ratings
be18driver
All Things Towing
Oct 28, 2018 10:21 PM
Krazyhorse
All Things Towing
Aug 6, 2017 06:11 PM
JandC
6.7L Power Stroke Diesel
73
Dec 12, 2014 08:38 AM
BulldogBob
Nov 6, 2008 04:27 PM
sstarnes
All Things Towing
May 4, 2004 06:42 AM
