Warm start issues
Old Aug 7, 2016 | 10:07 PM
BlueOx460's Avatar
BlueOx460
Warm start issues
I've tried reading other threads pertaining to my current issue, but I can't seem to find enough information. Ever since I've owned my truck, it's had a very hard time starting after driving it. There is a very rich smell of fuel as it cranks when warm. The starter also has a very hard time turning the motor over when warm (probably starter or starter wires though the starter is fairly new). Anyway, the previous owner said he replaced the fuel pressure regulator but I'm not sure where that is to check. Someone said possibly a temp sensor?
It's a 1988 f250 with a 460
Old Aug 8, 2016 | 12:06 PM
subford's Avatar
subford
More than likely a bad ECT sensor or ACT sensor.
The two sensors do not show up well when bad in EEC self-test as the computers has no idea if they giving the right information or not.
You will just have to take them out and test them.
ACT: Air Charge Temperature sensor or its signal circuit.
ECT: Engine Coolant Temperature sensor or its signal circuit.
EEC: Electronic Engine Control. A computer controlled system of engine control.
Old Aug 10, 2016 | 08:04 PM
BlueOx460's Avatar
BlueOx460
Hmm, I'm not sure where those are. When I unplug them do I see if it starts warm better, or is it something different
jemini
15
Aug 26, 2016 07:36 AM
timmygyu
1978 - 1996 Big Bronco
Oct 29, 2012 06:06 PM
1sscav
Sep 1, 2011 09:16 AM
meck1
Nov 11, 2005 02:49 PM
CharlestonSC
Aerostar
May 25, 2005 06:26 PM
