turn and brake light?
Old Aug 7, 2016 | 04:27 PM
mr.lothar's Avatar
mr.lothar
Have a 2009 Super Duty; turn signal an brake lights stopped working on my trailer. Tail lights an backup work. Put camper on the truck, same thing, so there must be a problem with the truck. All the lights work on the truck.
I replaced the left turn trailer relay, still nothing. Is there a fuse somewhere that could cause my problem?
thanks
Old Aug 7, 2016 | 05:51 PM
RV_Tech's Avatar
RV_Tech
Have you checked your seven pin to see what voltage you have, if any, at the terminals?
Steve
Old Aug 8, 2016 | 05:47 PM
mr.lothar's Avatar
mr.lothar
I just checked them; seems I was looking at the wrong fuse. Needed to check the one near the relay, it was bad. I believe the cable I use for both the truck camper an trailer has a short. Trailer has electric brakes so I need to use the 7-way for both.
Loveland
All Things Towing
Jun 20, 2012 05:59 PM
05superv10
Electrical Systems/Wiring
Jul 9, 2011 09:45 PM
southbound35west
Nov 30, 2009 08:36 PM
Danimal1481
May 17, 2009 09:07 AM
gutcheck
Apr 16, 2004 12:21 PM
