Is there any way to convert lb-ft into inch pounds? I thought that if you multipilied the lb-ft by 12, you could get inch pounds. The reason I ask is that my lb-ft torque wrench reads from 20 up, so I want to be able to use the inch pound wrench to torque bolts that are less than 20 lb-ft. Thanks
I've gotten boggled up in that too in the past. But I think you are right. Thus, if you needed to torque to 10 ft lbs, you would use 120 inch pounds on that wrench....I think.....
thats right tiger. 1 foot pound is the twisting force equal to placing a 1 pound weight on the end of a 1 foot long "weightless" wrench. one inch pound is the same only the weight is on the end of a 1 inch long bar.
Be careful torqueing anything below the 20ft lbs...this is below the normal working range of the wrench...I just got a inch lbs 1/4 drive wrench for doing accumulator bodies...
Also the 1/4" is much more accurate in this range...
According to a man I know that actually runs a metrology shop where they calibrate torque wrenches the ordinary Harbor freight wrenches are very good and hold up fairly well to normal hobby use. They are cheap enough that when it comes time to recalibrate you can just give them to the neighbor kid to use for a ratchet wrench and buy a new one
I haven't had a need for a 1/4" wrench yet but I have both a 3/8 and 1/2" Try not to operate any torque wrench or meter/instrument near the ends of the range. Always try to operate in the middle 2/3 of the range for accuracy.
From: Bama Gal transplanted to the Pacific North West
Torque Wrench Question
anything under my torque ratchet's range i use a torque wrench with the old metal bar pointer...as i have found the only way it is out of calibration is if the metal pointer is bent...and that you can see!
