Sponsored by: Real Truck
35s with 2.5 leveling kit?
Old Aug 5, 2016 | 03:51 PM
Lorrainethef250's Avatar
Lorrainethef250
Just got a leveling kit installed on my 05 F350, (coil spacers and shocks) and was wondering if there would be any problem with putting 35s on with it? They look like they'll fit no issue I just want to know if there is any rubbing anywhere I should be cautious of or just get 305 70 18s instead?
Old Aug 6, 2016 | 11:02 AM
RainDesert's Avatar
RainDesert
35x12.50x18 won't rub. I wouldn't go any wider then the 12.50 tire. I've seen pleny of that size on the stock wheel with and w/o a level.
Old Aug 6, 2016 | 11:22 AM
Lorrainethef250
Yeah I wasn't planning on doing more than a 12.5, considering I don't do that much offroading or mudding. I was just a little worried if I spent $1200+ for a new set of tires if they would rub and wear faster. Thanks for clearing that up for me!
Old Aug 6, 2016 | 12:10 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
With a 2" leveling kit 35x12.50R17 on (IIRC) -8mm offset wheels rubbed on the driver's side on my truck. Stock 18s cleared 295/70R18s even without the leveling kit, so using stock wheels 35x12.50 should be fine.
2" leveling kit and 295/70R18 NItto Trail Grapplers (34.5"x11.7" actual, and also cleared when the leveling kit came off):
35x12.50s that rubbed on the driver's side, but it's pretty obvious they're spaced out almost an inch further because of the wheel offset:
Hummah Zach
2004 - 2008 F150
21
Dec 10, 2009 03:41 PM
cdrmotorsports
Jul 23, 2009 04:34 PM
ggwash21
2004 - 2008 F150
15
Feb 19, 2009 07:50 PM
riored4v
2004 - 2008 F150
Oct 24, 2007 10:06 AM
Good Guy
2004 - 2008 F150
Apr 3, 2007 07:13 AM
