Engine size
Old Aug 5, 2016 | 09:49 AM
Guidochop's Avatar
Guidochop
Engine size
Hi everyone. I'm new to this forum & I own a 1976 Ford F100 custom pickup & are trying to figure out what the engine size is. My VIN # is F10BND01244. I've heard if you can decode the VIN, you can tell the engine size. Any help greatly appreciated.
Thanks,
Glenn
Old Aug 5, 2016 | 09:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN: F10BND01244
Welcome to FTE
F10 = F100 2WD Pickup.
B = 300 1V I-6.
N = Norfolk VA Assembly Plant.
D01244 = 1976.
Old Aug 5, 2016 | 10:35 AM
Guidochop's Avatar
Guidochop
Thanks, but what does the 300 1V I-6 mean?
Glenn
Old Aug 5, 2016 | 10:37 AM
Eli1644's Avatar
Eli1644
Thanks, but what does the 300 1V I-6 mean? Glenn
A inline 6 cylinder
Old Aug 5, 2016 | 10:53 AM
Guidochop's Avatar
Guidochop
OK, back to square one. It's a big block v8
Old Aug 5, 2016 | 10:54 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Glenn
(300) = 300 cubic inch (I-6) = inline 6 cylinder (1V)= 1 barrel carburetor. The "V" stands for venturi, the carburetor's "barrel". A four barrel carburetor would be listed as a 4V.
Old Aug 5, 2016 | 10:55 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, someone's done an engine swap. Count the number of bolts that hold one valve cover on.
Old Aug 5, 2016 | 11:31 AM
Guidochop's Avatar
Guidochop
There are 5 per valve cover.
Old Aug 5, 2016 | 11:53 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Five bolts means it's an FE series engine. That's going to be 352/360/390/406/410/427/428. With the exception of the 427, the only way to be sure of exactly which engine you've got is to measure the bore and stroke. Odds are though, it's going to be a 360 or 390.
Old Aug 5, 2016 | 01:32 PM
Guidochop's Avatar
Guidochop
Thanks for your help.
Old Aug 5, 2016 | 07:53 PM
NumberDummy
Is it an engine swap, or something else?
Compare the VIN on the Warranty Plate to the VIN on the registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Old Aug 5, 2016 | 11:16 PM
greentruck72's Avatar
greentruck72
a picture of said engine would help us make sure it is an FE. on the skirt of the block if it has bolts sticking out i'd say 427FE, however a 427FE is highly unlikely- most likely a 360 or 390.
Old Aug 6, 2016 | 01:04 AM
351Cleveland C4's Avatar
351Cleveland C4
C'mon guys! Let's be optimistic here! Maybe it's a 428 cobra jet! Or if he's really lucky, a 427 SOHC motor!!! Yeah!!!
Old Aug 6, 2016 | 08:38 AM
Guidochop's Avatar
Guidochop
The VIN # on the door matches the registration. The reason I wanted to know what size engine it is among other things is I'm thinking about doing a carburetor upgrade to it.
Glenn
Old Aug 6, 2016 | 09:44 AM
flowney's Avatar
flowney
That doesn't mean very much. What you want to do is locate the VIN that is stamped on the top rail of the passenger side frame just under the alternator on a V-8. What is stamped on the frame is definitive.
In my case ('76 F-150), the VIN on the warranty plate on the door and on the registration were the same but these did not match the VIN on the frame. Fortunately, I was able to correct the registration with the local tag office and obtain a new warranty plate from Marti.
Let's hope that the VIN on your frame matches the VIN on the registration and warranty plate.
