Sponsored by: Auxito
2001 Clutch
Old Aug 4, 2016 | 09:25 PM
damon_sisk's Avatar
damon_sisk
Red face 2001 Clutch
I recently purchased a 2001 F150 V6, 5 speed truck, ~95,000 miles, and sold my Ranger. I wasn't really sorry to see the Ranger go, I needed more pulling power.
A few weeks ago, I stupidly smoked the clutch on the F150 trying to back a trailer up my steep drive. Now the clutch is pretty much engaged even with the clutch pedal on the floor and its very hard to get the transmission into/out of gear. It is obvious the shaft coming into the transmission is spinning since the gears frequently grind before engagement. However, I can see the slave cylinder move through the port that has a removable rubber plug. I must have warped the flywheel pretty badly. I mainly use the truck for hauling wood during the winter, so I would like to upgrade the clutch to one that can take a little more heat/abuse.
Any suggestions?
I have already found that I should get the Ford slave cylinder because of the rubber boot covering on the revised part that protects it from dust (but wonder if any aftermarket slaves are the same now?) Just FYI, I also plan to replace the rear main seal in the engine, the seal in the front of the transmission, in addition to all the normal clutch stuff (flywheel/pilot bearing, etc.)
Please help me save money/time!
Old Aug 8, 2016 | 12:14 AM
brokenleg's Avatar
brokenleg
can tell you you are going to need a torch to heat up the bolts for the exhaust to remove the cats, and the Y pipe. probably will need to turn the flywheel, nothing is cheap.
van o
Dec 8, 2012 11:47 PM
mbxmitch
1983 - 2012 Ranger & B-Series
Nov 17, 2011 01:51 PM
ola1234
May 22, 2011 08:11 AM
longpoleman
Jan 16, 2008 01:05 PM
Kijutsu
Oct 19, 2007 03:50 PM
