Possible value?
Old Aug 3, 2016 | 01:03 AM
riot04's Avatar
riot04
Possible value?
Thinking about selling my truck since I don't seem to have the time/drive to finish and drive it. I have a 78 f150. Well as far as the title says. Pretty sure it was actually a body swap since title says 2wd with 351 but it's actually 4wd with a 400. It runs and drives. Fixed leaks cleaned out the 38 gal tank. Replaced fuel sending unit. Replaced water pump. Timing chain. Timing chain cover (pain in the *** to finally find) and other random stuff. Just wondering what they might go for since here in Vegas I can't find comperables. There's no real rust other since a little surface here and there since it's been in dry weather
Old Aug 3, 2016 | 11:26 AM
Jklnhyd's Avatar
Jklnhyd
I am in the Los Angeles area, so my opinion is just that.
I would guess that you would be lucky to get $2500-$2800.
A body swap.
The title of the vehicle matches the vin on the frame, not body, so you legally don't own that truck.
Old Aug 3, 2016 | 11:59 AM
greentruck72's Avatar
greentruck72
in south east kansas, that same truck could be anywhere from 1000 to 4500, i have seen them go higher. so good luck.
Old Aug 3, 2016 | 12:11 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Out in my neck of the midwest that is a F250 not a F150 (due to its 8 lug axle configuration) and looks to be a 1000 to 2500 dollar truck.
Paper title vi# goes to the frame stamped #, NOT the warrenty plate riveted to the dvrs door edge.
brokestroke
Jun 29, 2022 11:01 AM
bobj49f2
29
Mar 6, 2018 10:01 PM
Dsp29
1978 - 1996 Big Bronco
Aug 16, 2017 11:11 AM
Custom77F100
30
Feb 14, 2017 12:58 PM
wagners
Jul 20, 2015 10:36 PM
