Vacuum Modulator Replacement
Old Aug 2, 2016 | 09:32 PM
e30rik's Avatar
e30rik
So I replaced my transmission modulator the other day and I have a couple questions. First when I removed the old one ATF started pouring out like a drain plug, I just let it go till it stopped. At least a couple quarts came out. Is that normal? If not, how much should I buy to top off? More importantly, I'm not sure if I put it in right. I put the pin in the new one and pushed it into the hole and it snapped in and felt fine but I was able to push it in further but it kept popping back like a spring. I just pushed on it while tightening the bracket. Is that right or should I loosen it and let it sit where it wants? I haven't driven the truck yet because I need to buy atf and I want to make sure I didn't mess anything up by forcing the modulator in. any help appreciated, thanks
Old Aug 3, 2016 | 03:35 AM
FordFETruck's Avatar
FordFETruck
Which trans? sounds like a c6 from what you described. I had to push mine in while tightening the clamp down, it should be fully seated against the transmission case. I had a lot of fluid come out when I took mine out too but I kept my finger over the hole to minimize how much came out. So, yes that's pretty normal.
Old Aug 3, 2016 | 05:56 AM
Franklin2's Avatar
Franklin2
The tranny dipstick tells you how low you are on fluid. If it won't move when you go for a test ride, that is also an indicator you are really low.
If you messed the modulator up, it won't shift correctly.
Old Aug 3, 2016 | 11:31 AM
e30rik's Avatar
e30rik
Yeah, it's a C6. Sounds like I put it in right then. Only asked about the fluid because I'm not sure how accurate a cold reading is and I don't want to drive it if it's too low but I'm sure it'll give me a good enough idea. Thanks guys!
82f100460
32
Mar 3, 2012 10:59 PM
7Ford6
Aug 7, 2010 12:32 AM
Sycostang67
Nov 4, 2009 10:17 AM
redwood
Feb 7, 2006 11:32 AM
guillermorivera
Oct 31, 2005 10:10 AM
