Tranny comparisons
Old Aug 1, 2016 | 09:33 PM
POWER-RANCH's Avatar
POWER-RANCH
Tranny comparisons
Alright, so i've had an '02 f250 for about 6 years now and an '01 f250 for about 3 and they both shift pretty much the same. 02 shifts a tad different depending which setting the ts6 is on. But overall feels about the same. I bought a L99 f350 a couple weeks ago to replace the 01, (work trucks). I can definitely tell the gearing in the diff is different but the transmission in the late 99 shifts way different than the other two trucks. I was just wondering if someone could shed some light on this for me. I was told the 99 is all stock. looks to be so motor wise.
Thanks in advance.
Ps 01 is all stock to.
Old Aug 1, 2016 | 09:40 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's simply the way and when the transmission is commanded to shift based on the calibration in the powertrain control module.
Old Aug 1, 2016 | 10:08 PM
POWER-RANCH
Does the 99 have the same transmission as the other two? or is it just the pcm is programmed different in the 99's?
Old Aug 2, 2016 | 06:35 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Same transmission.
Old Aug 2, 2016 | 08:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's the programming. The transmissions are identical.
Old Aug 2, 2016 | 11:43 AM
POWER-RANCH
ok thanks for the great info. One more question, riffraff has the ts 6 position on sale and i really like it in my '02. I'm guessing if i install that it will shift like the '02???
also do you guys like the gearing on the 1 tons? I'm running 2400rpms at 74 Mph. Im pretty sure it has stock size tires.
Old Aug 2, 2016 | 12:02 PM
coax9952's Avatar
coax9952
No, It will shift like a 99 with tweaks....A tuner doesn't change your Base PCM program, They rearrange some of the performance parameters.
Old Aug 2, 2016 | 12:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Wrong.
It depends on the current calibration in the PCM.
Old Aug 2, 2016 | 01:03 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If you get a TS Performance brand chip, then it will shift pretty much exactly like it does now. However if the one you buy from KT performance is the power-hungry Phoenix athen yes it will shift like your 02. TS performance does not use the same calibration as other tuning companies.
flavo
Oct 15, 2015 10:39 AM
THEWFO
Engine Swaps
Dec 19, 2009 08:48 AM
joegebff
Feb 1, 2008 07:22 PM
Calan
Aug 3, 2005 10:03 AM
