Sponsored by: Auxito
2000 f150 AC problem
Old Aug 1, 2016 | 03:37 PM
nick c's Avatar
nick c
I was driving my f150 with the AC on, it has a 4 position fan switch. Lo, 1 , 2, and Hi. The fan only works on Hi. I don't think its a fuse, so what are the possibilities ?
thanks nick c
Old Aug 1, 2016 | 03:46 PM
6.0owner's Avatar
6.0owner
I can name maybe 3... the fan switch.. the fan blower motor... or your blower squirrel-cage is full of leaves and stuff so it can only move at full power.
Old Aug 1, 2016 | 08:30 PM
steve(ill)'s Avatar
steve(ill)
the fan 4 speeds are set by running 12 volts thru a series of resistors and dropping the voltage to the fan. The selector switch chooses which resistors are needed...... the resistor block is about the size of an ice cube.. It is bolted to the bottom of the air duct, below the glove box. Lay on the passenger floor and look up at the duct... look for a 4 wire connector on a small black cube.. Two small bolts connect it and it sets INSIDE the duct hole so cool air can keep it cool. .... Pull it out and look... sometimes the resistor burns out, sometimes the plug is damaged.. sometimes due to a bad ground on the system. ....... the switch is less likely but possible.
Old Aug 1, 2016 | 08:32 PM
steve(ill)'s Avatar
steve(ill)
4L3Z19A706AA 973 015 Heater Blower Motor Resistor Fit for Ford F 150 | eBay
seagiant
Jul 19, 2016 11:23 AM
steverodd
2004 - 2008 F150
Nov 10, 2014 07:50 PM
Chris_N
1997 - 2003 F150
Aug 21, 2008 09:49 PM
mikepa
Sep 28, 2004 03:53 PM
prospero
Aug 23, 2003 12:52 PM
