So i just have a simple question for you all, atleast i hope it is lol..
I have a 65 swb 2wd with the 3 on the tree trans, not sure exactly what model but it was attached to a 240I even though i was told from the guy i bought it from it was a 300I but anyway, I am going to swap the old trans with a borg warner t5 with a 351w and have read a couple times that i could use the old bell housing with the t5 and will bolt on to the 351w is this true? any advice or suggestions will be very helpful..
if your t5 is a ford spec t5 just get a standard 85 93 5.0 bell housing. it will have the proper dimensions for the input shaft. 300 i6 has same bh pattern as small block fords. parts are plentiful.
