Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decoding Help 1965 N600
Old Jul 27, 2016 | 07:30 PM
62FE4x4's Avatar
62FE4x4
I had been looking for a H1000 to use when moving my flatbed and my 5th wheel camper around asa backup in case my 94 F350 Diesel ever goes down. Today I came across a 1965 N600 by hapoen stance. It is an old Fire truck, and it only has 72,000 original miles. I will try to post a photo of the data plate if Bill or someone else comes along who can decode this beast.... very neat old truck
Old Jul 29, 2016 | 07:53 AM
awhtx's Avatar
awhtx
A word of caution: even though it may only have 72K miles the engine has spent thousands of hours running a pump while the truck sat still. Don't expect the engine to be in like-new condition.
I bought a 1958 F600 that was a former grain truck and had 50K miles. It was only used 3 months out of the year hauling grain from the field to the grain elevator but those miles were hard ones. It definitely had wear on it!
Old Jul 29, 2016 | 09:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 62FE4x4
I had been looking for a H1000 to use when moving my flatbed and my 5th wheel camper around asa backup in case my 94 F350 Diesel ever goes down. Today I came across a 1965 N600 by happen stance. It is an old Fire truck, and it only has 72,000 original miles. I will try to post a photo of the data plate if Bill or someone else comes along who can decode this beast.... very neat old truck
N60 = N600.
A = 330 2V Medium Duty FT engine.
U = Louisville KY Assembly Plant.
613371 = 1965, assembled November 1964.
163" Wheelbase.
L = Holly Green.
N601 = N600 .. 15,000 lbs. GVWR
M81A: M = Light Beige Crush Vinyl & Light Beige Ladder Pattern Woven Plastic / 81A = Standard Cab.
L = Clark model 2651-V1 5 Speed Direct.
G3C:
G3 = Eaton model 16802 Two Speed Rear Axle / 6.50/9.04 / 17,000 lbs. Rear Axle Capacity.
C = Ford-Rockwell/Timken 6,000 lbs. Capacity Front Axle.
15,000 lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
63 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
In another thread, you posted pics of the engine. The pictured Powered by Ford valve covers were introduced in 1967, so the engine may have been swapped.
Do not believe the miles shown on the odometer, as it reads to 99999.9 then returns to ZERO!
Old Jul 29, 2016 | 11:02 AM
62FE4x4's Avatar
62FE4x4
Decoding
Thanks Bill,
With the 330 I am sure it would be weak, but with a rearend geared that low I am sure it would pull my Camper, Flatbed, and anything my 94 Powerstroke F350 would touch. It would just get it there the next day. Haha. They swear the mikes are accurate. Original firetruck
Old Aug 7, 2016 | 02:03 PM
80broncoman's Avatar
80broncoman
Thanks Bill,
Keep in mind the tall height of those tires will make the gears seem higher than comparing those gear numbers to other vehicles with more "Normal" tire sizes.
the_webers_inc
41
Sep 24, 2020 05:56 PM
iceberg210
Large Truck
Nov 20, 2018 03:21 PM
izaquad
Large Truck
Feb 6, 2018 09:52 PM
62FE4x4
Large Truck
Mar 14, 2017 08:58 AM
cmongft
Large Truck
Sep 17, 2014 02:42 PM
