update propane system
Old Aug 18, 2003 | 09:51 PM
canbman's Avatar
canbman
Question update propane system
I have a 77 f-250with a 460 on propane.now i love the engine ive heard the proformance now is no where near how it ran on gasoline. ide love to go back to gas this is not an option up here on the wet oooops,west coast of canada as the price of petrol is quite expensive.the propane sys. is fairly old im guessing,is there any way of updating or making the one i have now work better?any input would be appreciated
Old Aug 19, 2003 | 01:22 AM
Ford_Six's Avatar
Ford_Six
Well, propane is about 130 octane, so you can really go wild with the engine. Decent RV cam, plane the heads, or put in pop-up pistons. You should be able to run around 11:1 compression with no problems. As far as updates for the system, I don't know too much about the propane systems themselves, but I am sure some around here do.
Old Aug 19, 2003 | 09:12 AM
gasman6674's Avatar
gasman6674
Is it dual fuel or straight LP?
Do you know the name of the equipment? Should be on the front of the vaporiser. LP performance usally suffers because the engine does not get set-up properly. As Jared mentioned if you are running LP Only you can tweak the timing and increase performance. LP requires a high intial advance but a fairly short curve 28-32deg total @ 3000-3500rpm of course if you have the facilities you can play with the curve to suit your needs.
Hope this Helps
Old Aug 19, 2003 | 02:09 PM
VX's Avatar
VX
http://franzh.home.texas.net/engine.html
Good info there.
BluecreekGT
Alternative Fuels, Hybrids & Mileage
Mar 8, 2013 09:29 AM
fishindave11
Apr 22, 2007 10:34 AM
commonhack
Bio-diesel, Propane & Alternative Diesel Engine Fuels
13
Oct 4, 2005 01:12 PM
96ford4x4turbodiesel
27
Mar 10, 2004 01:05 AM
Zed
17
Jun 9, 2002 11:20 AM
