Cannot tow my excursion
Old Jul 22, 2016 | 05:10 PM
sschwenzer's Avatar
sschwenzer
Question Cannot tow my excursion
Hey. I have a 2000 7.3 Diesel Excursion that broke down last August. I finally have the time and finances to try and troubleshoot and fix it. It is currently sitting outside my barn where the rollback dropped it last year. It has not been started since then but I have had a battery conditioner on it the whole time and it turns over just fine.
My problem is that when I got to tow it over to the garage with my tractor, I can't get it to move. I shift it (column shifter) into neutral and verify that it does shift down at the transmission. Then I go to pull it and it just won't budge. It moves slightly forward like it is still in park but won't roll. I have put the rear end up in the air and checked the brakes...they are fine. When I turn the rear wheels they rotate the drive shaft slightly before they hit up against a hard stop.
Any help would be greatly appreciated.
Old Jul 22, 2016 | 05:45 PM
gots_a_sol's Avatar
gots_a_sol
Drop the rear driveshaft so you can move it?
Old Jul 22, 2016 | 05:53 PM
Skip1970's Avatar
Skip1970
rusted pads to brake disc ive seen it before
Old Jul 23, 2016 | 07:00 AM
fordboy2's Avatar
fordboy2
I agree with pulling the drive shaft and see if it moves. If not then you'll know it's the rear brakes etc.
Old Jul 23, 2016 | 12:10 PM
pirate4x4_camo's Avatar
pirate4x4_camo
How did you check the brakes ?
If you checked the brakes by rotating the tires can you freely spin them for many revolutions ?
I am trying to understand what you mean by they hit a hard stop. This sounds to me like the tires will jostle back and forth a smidge and then the drive shaft stops them from rotating because the vehicle is is park or the transmission is locked up.
Old Jul 24, 2016 | 02:35 PM
jayjordon's Avatar
jayjordon
Seriously? LOL. Locked up tranny, or axle, or brakes. Not really too hard to figure out...might be a PITA to fix though...
Old Jul 24, 2016 | 11:55 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Some people here are new or of little mechanical aptitude. That's why they come here, for helpful suggestions and advice.
Not to have someone belittle them over it. The OP is brand new, this is their intro post. But nice first impression of our forum, good job
Old Jul 25, 2016 | 06:07 AM
locknload223's Avatar
locknload223
^ Agreed!!
Old Jul 25, 2016 | 07:34 AM
DSN46's Avatar
DSN46
I agree with pulling the drive shaft also. Once that is done, your only choices are brakes frozen or bearings. Good luck!
Old Jul 25, 2016 | 07:50 AM
pirate4x4_camo
Unless the problem is in the front axle
Old Jul 25, 2016 | 09:19 AM
DSN46's Avatar
DSN46
I guess I never saw where he said it was 4X4...
Old Jul 27, 2016 | 05:03 PM
jayjordon's Avatar
jayjordon
You fellas need to loosen up. This wasn't meant to be anything other than friendly, with a chuckle. I hope the OP has thicker skin that you...
Old Jul 27, 2016 | 06:04 PM
WE3ZS's Avatar
WE3ZS
Hey Jay, I know that you have been around here for a couple of years now, but maybe with your very low post count you haven't become used to using the various smilies to convey when you are joking around.
Online forums, where all we can see is the written word with no facial expressions, vocal inflections, or body language can lead to misunderstandings due to how we phase things. Those dopey little smile guys can help make it clear when we are having fun vs being blunt (or worse ).
As far as online forums in general go, this one is pretty damned good, with lots of good folks willing to share knowledge and help each other out. It's not uncommon for the regulars to be quick to protect this place and it's positive vibe when they feel that someone isn't playing nicely. I think that's what we saw above, I hope you can see how your first post in this thread could be seen as a little cold/hard where a new guy is just looking for some help.
Now hopefully we can all get back to helping sschwenzer (if he ever comes back around....) get his EX moving and running again!
Old Jul 27, 2016 | 10:18 PM
Krazee Matt
Veteran: Navy
Like Tom already covered, smiley's would've helped get the joking nature across. My skin is plenty thick, I have no problems coming in and making sure people feel welcome is all.
I've had my fair share of warnings and personal phone calls from mods when SHTF and I voice my opinion of someone or their actions. The last one is hiding somewhere in FTE mod infamy, hah.
You've been around almost as long as I have, come visit and post with us more often and you'll learn that I'm fun and a little... crazy
Old Jul 27, 2016 | 10:53 PM
J ballan's Avatar
J ballan
Before a guy goes pulling driveshafts off I would make sure they didn't put the e-brake on after they towed it. I know that seems silly but I've spent many hours pulling wrenches because I overthought something. Lol. Also if it's a 4x4 you could put the transfer case in neutral, might help narrow it down. Good luck.
