Sponsored by: Auxito
Lower ball joint replacement
Old Jul 25, 2016 | 04:25 PM
Patriotgrunt's Avatar
Patriotgrunt
Trailering
How difficult is it to replace the ball joints on a 2003 Ford F-150 4x4? I've watched a video on youtube which looks pretty easy but I don't want to jump into a project I can't finish. While I'm in there, do you recommend changing out the upper control arms or tie rods also? Thanks in advance for any responses.
Old Jul 25, 2016 | 06:02 PM
steve(ill)'s Avatar
steve(ill)
IF you borrow the "ball joint press" from the Auto Store or have your own, its not too bad... I bought a cheap press at Harbor Freight.. The " spacer sleeve" did not fit the frame exactly right and I had to modify ( grind) it a little to seat correctly... Having an air impact gun is a good idea to push screw the press rod down against the ball joint to pop it out............ don't forget the snap ring on the bottom that holds it in.
Rembrant
Sep 23, 2017 04:31 PM
f250d4x4
1997 - 2003 F150
May 19, 2014 09:49 PM
Hookster
1997 - 2003 F150
Apr 11, 2009 04:44 PM
gingerbreadmaniac
Jul 28, 2005 02:03 AM
jeffomaclean
1983 - 2012 Ranger & B-Series
May 1, 2005 01:31 AM
