Dremel Tools
Old Jul 25, 2016 | 03:22 PM
ChuckRob's Avatar
ChuckRob
Dremel Tools
I just burned through another Dremel 4000 tool, it went up in smoke. Are any of the Dremel tools worth a crap these days? Am I just better off going to Harbor Freight. at least when they burn up your only out $25.00 ant $90.00
Old Jul 25, 2016 | 03:24 PM
itsnotavan's Avatar
itsnotavan
ever thought about going to a air die grinder?
Old Jul 25, 2016 | 03:27 PM
emay's Avatar
emay
I look at the dremel product as a hobby/craft tool. Very light duty.
I go to my rotozip (dependent on task) when I think I'm going to push the Dremel's.
Old Jul 25, 2016 | 04:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not sure what model Dremel I have, but's about 15 yrs old and going strong. 90% of its use is with the thin cut-off discs, the rest for buffing. It's paid for itself many times over, especially cutting rusted nuts off on the front end of my truck.
Old Jul 25, 2016 | 05:15 PM
jniolon's Avatar
jniolon
old and in the way
any chance it might need a brush replacement...
Old Jul 25, 2016 | 05:19 PM
3twinridges's Avatar
3twinridges
My dremel with the harbor freight stainless brush sets is my number 1 used tool probably for rust restoration after a short bath in prep and etch.
Old Jul 25, 2016 | 05:40 PM
ChuckRob's Avatar
ChuckRob
My first Dremel lasted 15+ years, same type of usage. In the last six years I have burned up three, this one cutting light guage aluminium.
Old Jul 25, 2016 | 05:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I checked, mine is model 935, Made in USA. Are they still made here?
Old Jul 25, 2016 | 05:57 PM
ChuckRob's Avatar
ChuckRob
They don't make the 935 anymore, wish they did. The 4000 is made in Mexico. As long as they are not made in the States I might as well try the Harbor Freight.
Old Jul 25, 2016 | 06:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might give the die grinder at HF a shot. It uses 1/4" shank tools, but it's only $15 I think.
Old Jul 25, 2016 | 07:22 PM
toby tough's Avatar
toby tough
I had one of the older ones years ago when I had the bikes. Handy little units. Loaned it to my buddy and haven't seen it since. Built in Mexico? My daughters Jetta (money pit)was built there.
Old Jul 25, 2016 | 08:45 PM
CharlieLed's Avatar
CharlieLed
If you want a professional product you may want to check out the Metabo line https://www.metabo.com/us/enus/tools...g/die-grinder/
I have a GE700 that I have used for years for cutting, porting, and polishing. This uses a 1/4 inch arbor and has enough torque to wear you out.
Old Jul 25, 2016 | 10:21 PM
filthy6's Avatar
filthy6
I finally gave up and went the HF route. Figured they were cheap and if I broke it I could return it or just buy another. It has lasted very well. Well enough that at high speeds it has bent many of the accessories.Be careful and wear your safety equipment please.
curkey
Garage & Workshop
41
Nov 13, 2013 05:47 PM
Fordenthusiasts
Garage & Workshop
36
Apr 22, 2008 04:47 PM
AndrewHR
Garage & Workshop
24
Jan 7, 2006 08:56 PM
rangersvt04
Garage & Workshop
75
May 13, 2004 10:32 AM
Indybroncoman
Garage & Workshop
May 10, 2004 09:11 AM
