Tire diameter change requires diff change?
Old Jul 25, 2016 | 06:08 AM
Toppa's Avatar
Toppa
Hey Folks,
I gonna' Change my tires from 29" to 31 1/2". Sure the engine will Need more torq to accelerate the car. Will i have to Change the diff trans Ratio? or will the 5.4L able to push it ?
Old Jul 25, 2016 | 08:44 AM
dcgayhart's Avatar
dcgayhart
The distance traveled by the tire on 29's is 91.089 vs 98.942 on 31.5"or 7.852". You didn't mention you current gear ratio. Check your mileage, if it changes more than 10-15% or you are towing at the upper limits of your vehicle I wouldn't be to concerned.
Old Jul 25, 2016 | 09:37 AM
baddad457's Avatar
baddad457
If you have 3.55's now, then the taller tires will be like reducing that to 3.27's.
Old Jul 25, 2016 | 10:32 AM
KarstenP's Avatar
KarstenP
Power will drop noticeable, but not too bad. I even tow with my 5.4 on 32's with the stock 3.73 rear end ratio.
Note that your speedo will be off by 7-10%
Old Jul 25, 2016 | 06:55 PM
jbwheels's Avatar
jbwheels
I have a 97 E250 with 5.4 and 3.73 gears.
Stock tires 225/75-16 29.5" diameter
Changed to 245/75-16 30.5" diameter because there are more options.
Not as big a change as you're looking at but the only thing I noticed was the speedometer is actually more accurate. Almost spot on now.
Still hauls loads and tows trailers with no problems
Old Jul 26, 2016 | 02:03 AM
Toppa's Avatar
Toppa
good to know. sure i knew about the speedo and the Change, but hard to guess how bad it will be if you never tried. thanks for your experience reports
Old Jul 26, 2016 | 01:16 PM
Mike1's Avatar
Mike1
I have an 03 F350 4x4 5.4L auto, It had 20" wheels with 305/55/20 Nitto grapplers with 3:55, The truck couldn't get out of it's own way to save it's life, I found a stock chrome set of 16" wheels and tires and now the truck has all the power one could ask for, and the speedo is only off by 5mph, where it was off by 13mph before.
Old Jul 26, 2016 | 07:55 PM
jayro88's Avatar
jayro88
I went from 225/75r16 to 235/85r16 and could definitly feel the difference in acceleration after the bigger tires. My van has 3.54s. I have an auxiliary OD that i usually just left on high with the old tires. While i still can leave it in high foe city driving it feels very sluggish off the line. I haven't had a trailer hooked up since the tire swap, but i think i will be putting the OD in low for city or any stop and go action.......which i didnt have to do before. The big benefit for me was lower rpms at hwy speeds which helped with hwy mileage and cabin noise. I believe it hurt my city mileage a little though.
Old Jul 28, 2016 | 01:03 AM
Toppa's Avatar
Toppa
changed the tires now. The difference between 225-75-16 and 265-75-16 is considerable. in the Corner the tire is softer cause of the bigger hight. so the car is dunking a Little. the Ratio Change is really noticeable, but acceptable. speedo changed about 8km/h while driving 100Km/h.
sure the handling Performance doenst improve but the optic is enormous!
karsten p was right, i had to cut out a Little of the tir housing, but only about 4 cm on the bottom rearpart of the front housing. reward is a awesome look, will post some Pictures later. Im at work at the Moment ;-)
sscarboro
Aug 29, 2012 01:36 AM
DUALLYNOTED
May 5, 2007 11:35 PM
1984F15016
Jul 18, 2004 07:10 PM
jwtaylor
Oct 2, 2001 04:15 PM
CJay
Mar 16, 2000 05:38 PM
