differential change
Old May 1, 2007 | 05:46 PM
DUALLYNOTED's Avatar
DUALLYNOTED
Thumbs up differential change
My diff is a 4.10 is it easy to change it to make it better for towing? I know 4.10 is enough but I need more towing power and I figure Id change the rear diff. ?? If I can
Old May 1, 2007 | 06:04 PM
ReAX's Avatar
ReAX
Do not attempt it by yourself if you have never done it before or don't posses the proper tools. It's not a shade tree job, you should have dial indicators, marking compound, shims and a press.
Old May 5, 2007 | 11:35 PM
guessrow's Avatar
guessrow
what about shorter tires??
I don't know if this is an option, but smaller tires will also change your final gear ratio.
good luck- jim
