Sponsored by: Kumho
Torsion bar adjustment
Old Aug 18, 2003 | 08:11 PM
danike's Avatar
danike
I tightened the adjusting bolts on my truck to raise the front end up 1 inch, but I didn't jack up the front end to relieve the tension on the suspension. Will this cause any damage? How far can it be raise without the alignment going out of spec.? I also had to give the pass. side bolt 1 more turn than the drivers to get the height and to be level. My truck also came from the factory with drivers side bolt turned in farther than the passenger side, but still have a couple threads left after lifting.
Old Aug 20, 2003 | 06:40 AM
Shernius's Avatar
Shernius
I’m not sure as I’m also looking into this now but I noticed that my truck also has the drivers side turned more than the passenger side from the factory. It’s turned in about a1/2-3/4” more.
Old Aug 20, 2003 | 09:13 PM
claynewt's Avatar
claynewt
Hey fellas....Just got 03f150 screw FX4 Lariat. Buddy out of state has one also. He mentioned he adjusted his bars to bring up front end.
How does this affect: ride comfort
tire/wheel alignment
gas mileage
handling
I wanted to level out my rig just a bit but didn't want to mess w/ factory settings....they must build the truck w/ a raked look for a reason right?
If it's acceptable, what is the procedure to do this.
Also what are lowering shackles? Do they just clamp down the rear end?
Enough.....let someone answer.
thanks,
Old Aug 20, 2003 | 09:28 PM
danike's Avatar
danike
Mine rides and handles the same and the mileage didn't change.
Still waiting for answers on the alignment question.
Old Aug 20, 2003 | 09:33 PM
claynewt's Avatar
claynewt
What's the procedure? Do you have to unload the suspension?
Thanks.
Old Aug 20, 2003 | 09:34 PM
Shernius's Avatar
Shernius
It took 3 full turns of the bolt to raise the right side up 5/8” to even it with the left side. I just wanted to get the truck evened out. Plus it felt like it had a bad shock and they are new. Search around in the 97-03 section, as there is a lot of talk on cranking up the adjuster to bring the front end up.
Old Aug 20, 2003 | 09:40 PM
claynewt's Avatar
claynewt
Preciate it. I'll check it out.
Old Aug 21, 2003 | 03:17 PM
natewoz's Avatar
natewoz
Most things I have heard about "cranking up the bars" is your ball joints may wear faster. Almost every story I have heard of cranking up Chevy trucks an Dodge Dakotas seem to end with new ball joints.
Old Aug 24, 2003 | 10:29 PM
Trek93023's Avatar
Trek93023
I just cranked my bars and i have 11 inches clearance between the top of the front tire and the fender, and 9 inches in the rear.....i turned the drivers side 5 times and the passenger side4 times....the passenger side is turned up as far as it will go...but both sides are exactly even. I may let it back down tho until i have to go and get another realignment because i didnt want to make a special trip for that. Thats 45 bucks...i can wait.
Old Aug 25, 2003 | 06:14 AM
Shernius's Avatar
Shernius
Doesn’t your truck look like a boat going down the road now with the front end up in the air?
Old Aug 25, 2003 | 05:17 PM
Trek93023's Avatar
Trek93023
nope....2 inches sounds like a lot but it just looks a little more aggressive....its not what you think...believe me i wouldnt want it to look stupid
Old Aug 26, 2003 | 07:04 PM
claynewt's Avatar
claynewt
Trek93023........Did you have to unweight the front end to get your adjustments?
Old Aug 26, 2003 | 09:04 PM
Trek93023's Avatar
Trek93023
yes...it makes it much easier to turn the adjustment bolts. I just lifted the front end until the tires were barely off the ground....this was enough to take the strain off the suspension.
Wesley Fox
Jul 11, 2016 12:11 PM
CoachMikeSC
Jan 25, 2016 09:54 PM
rj63
Jun 21, 2012 01:10 PM
jferrar5
Jun 1, 2010 09:38 AM
markcarver
1997 - 2003 F150
Apr 1, 2008 02:28 PM
