Need a differential/proportioning valve
Old Feb 7, 2017 | 05:42 PM
tbruz's Avatar
tbruz
Distribution Block- 67 Mustang - A1419
Works perfect but I had to change the flare nuts on my brake lines to fit the new distribution blocks threads.
Had to trim the bottom off the mounting bracket a bit as well.
Thanks
Tbruz
Old Feb 7, 2017 | 08:12 PM
mikeceli's Avatar
mikeceli
Thanks
Tbruz
Thank you! How did you change the flare nuts? Adapters? Cut line, new nut , double flare? MC
Old Feb 7, 2017 | 08:51 PM
tbruz's Avatar
tbruz
I cut off the old trashed nuts and put on the correct matching size nuts and
Re-flared the lines.
You can get a flare tool along with a length of brake line pretty cheaply to practice your cuts and flares on.
Tbruz
Old Feb 7, 2017 | 09:20 PM
ultraranger's Avatar
ultraranger
3/8"-24 is the standard sized inverted flare fitting for 3/16" diameter brake tubing. (2) of these fittings will come on the 3/16" various length brake tubing you get at the parts stores. The 3/8"-24 flare nut fittings are also available, individually, from the parts stores.
However, Ford also used 7/16"-24, 1/2"-20 and 9/16"-18 inverted flare nut fittings with a center hole designed to fit on 3/16" diameter brake tubing. These are specialty sized fittings that the parts stores generally do not carry. --this is the part where they usually point you to the fitting adapters bin. Adapters don't give a professional looking installation.
These specialty sized (direct connection) fittings are available brand new through Classic Tube.
The 7/16"-24 fitting is part number ST8006. The 1/2"-20 fitting is part number ST8007. The 9/16"-18 fitting is part number ST8010.
Old Feb 7, 2017 | 09:32 PM
tbruz's Avatar
tbruz
The distribution block I used, SSBC A1419 uses three 1/2 x 20 fitting; one 7/16 x 24 and one 3/8 x 24.
Thanks
Tbruz
captainwoot
May 11, 2017 09:18 PM
Mikulh
19
Aug 3, 2016 04:52 PM
WoodBoss
May 19, 2015 11:36 AM
ChrisAU
Ford Truck Parts for Sale
Mar 4, 2013 07:06 AM
rellikkcaj
Apr 15, 2007 12:44 AM
