06 explorer cranks but won't start
Welcome to the forum!
When you say "it has fire" do you mean that you confirmed there is spark at a spark plug wire?
Did you just confirm that fuel sprays from the pressure valve when depressed, or did you actually install a gauge and confirm the fuel pressure is where it should be?
Was the truck driving fine up to the point that it stalled?
Have you checked under the hood for any disconnected lines, such as the intake air tubing between the air filter and the throttle body?
Has any service been performed recently that would have had someone under the hood?
Did you try holding the accelerator pedal all the way to the floor when engaging the starter in case the cylinders were flooded?
-Rod
-Rod
Explorer180
03-15-2011 10:32 PM
boaterdude83
02-07-2009 12:39 PM
dmc919
05-20-2007 01:18 PM
