My power steering is only working when i turn it to the left. When I turn it to the right i have to get a 1/4 of a turn in untill the power steering takes over. So i get under my truck to descover what seems to be a peice of my tranny missing. How screwed am I ???
The only thing I see in the picture is the inspection cover isn't there. It would be a good idea to get a new one.
It also looks like your missing one of the nuts that bolt the torque converter to the flex plate (last picture). I would spin it over and check them all and replace/ tighten as needed. Are you having any other transmission issues?
The last pic is a pic I found offline to get a better visual
I did not see that. Change the Subject to something with 4R100 or Transmission and Mark K will chime in as he was an Engineer for Ford and can tell you the specifics of the Bolt needed.
