Hood insulation
Old Jul 22, 2016 | 04:24 PM
Jeff53's Avatar
Jeff53
Hood insulation
For those who have added the factory hood insulation to later model Excursions that came without it, have you noticed much/any difference in noise level inside the vehicle? Is there any real benefit to adding it? Thanks.
Old Jul 23, 2016 | 12:38 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Well I've run with and without, there is zero difference except heat waves on the hood surface. You won't get any noise difference, not unless you sound deaden the firewall. Thermal insulation on the hood, feet away, and outside, isn't going to do diddly squat for dampening perceived engine noise in the passenger compartment.
Old Jul 23, 2016 | 01:30 PM
Jeff53's Avatar
Jeff53
Thanks
So, I guess the only real benefit to it would be keeping the hood surface cooler, if that would be considered a benefit.
Old Jul 23, 2016 | 04:11 PM
Krazee Matt
Veteran: Navy
That's the only thing I have found. Personally the more heat that can get out the better, even if it is just heat transfer through metallurgical properties...
Old Jul 23, 2016 | 08:49 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
With our 6.0 its slightly quieter above the hood, if that matters. In mn it might keep some of the latent heat from the engine under the hood, good for the cold? It looks like it belongs there, better looking, and and good for glueing my led light too!
jpmillbauer
Apr 13, 2016 12:01 AM
jr2000sd
Aug 4, 2014 07:37 PM
410 Highboy
Apr 4, 2009 01:16 PM
pilot10
1997 - 2003 F150
Apr 28, 2004 01:06 AM
Matt03Expy
Dec 6, 2003 11:40 PM
