98 explorer evap codes Ltfs -100
Old Jul 21, 2016 | 08:44 PM
Mark Hanners's Avatar
Mark Hanners
Idles slightly rough bogs and pops thru air box very intermittently very poor fuel mileage. Only codes is for air leak evap. Fuel pump was replaced less than 2000 miles back along with filter. Fuel pressure at idle 36-38psi long term and short term trims fixed at -100 so running rich. O2 s bank 1 0000 bank 2 n/a. All other pids look good question acts like maf going to test it in morning but ive fixed many evap codes with no lean issues is it possible it is leaning out as fuel pressure seems fine. Also no vac leaks obvious again will check intake ect in morning itsmy brothers and not here tonight wanting to get info beforehand why is the bank 2 reading n/a but fuel trim is reading -100 my scanner goes back to 96 and ive checked pids on many mid late 90s no problems so dont think its scanner im a retired Master Ford tech went into management in 96 still around it till 2010 but with IDS and only overseeing the shop so my knowledge has dwindled considerably but usually able to handle most drivability and probably ran into this exact problem just forgpt it.
Lol Thanks
Armyrules2
Nov 20, 2018 03:31 PM
gwmontgomeryjr
Oct 2, 2010 11:02 PM
Pipe Burn
1983 - 2012 Ranger & B-Series
15
Jun 29, 2010 12:27 AM
CTf250
Jan 4, 2008 06:49 PM
ltfox
Dec 31, 2003 04:48 PM
