Lower fuel filter housing
All put back together. Cycled 8 times. Tapped the key and it cranked for about two seconds and off it went. Idled fine but then I noticed the wrench light come on. Ugh. Took it for a quick run down the road and it drove fine. Turned the truck off then back on and the wrench went away. Is this something I should be concerned about or do you think it was just from the partially dry fuel system?
I'm betting it was temporary low fuel pressure that went away after the system got out the remainder of the air.
With the truck off, hold down the DOWN arrow on the steering wheel, turn to the truck to ON but don't start. It will go into engineering mode and tell you if you have any hard codes stored. I bet you don't...
05 f250 6 inch lift
08-28-2012 10:55 AM
