Lower fuel filter housing
Old Jul 20, 2016 | 06:21 PM
Dakster's Avatar
Dakster
But don't over tighten and break it either....
Old Jul 20, 2016 | 07:19 PM
garmford's Avatar
garmford
All put back together. Cycled 8 times. Tapped the key and it cranked for about two seconds and off it went. Idled fine but then I noticed the wrench light come on. Ugh. Took it for a quick run down the road and it drove fine. Turned the truck off then back on and the wrench went away. Is this something I should be concerned about or do you think it was just from the partially dry fuel system?
Old Jul 20, 2016 | 07:20 PM
Dakster's Avatar
Dakster
I'm betting it was temporary low fuel pressure that went away after the system got out the remainder of the air.
With the truck off, hold down the DOWN arrow on the steering wheel, turn to the truck to ON but don't start. It will go into engineering mode and tell you if you have any hard codes stored. I bet you don't...
Old Jul 20, 2016 | 07:48 PM
EO2SeaBee's Avatar
EO2SeaBee
Glad you got it fixed up. Now, order a spare bowl to keep with you!
Old Jul 20, 2016 | 08:33 PM
garmford's Avatar
garmford
I did go into the engineering screen when I got home and your right, no codes were stored. And I agree, I must get another bowl in my possession before it happens again.
Old Jul 22, 2016 | 06:39 PM
Icthus in AK's Avatar
Icthus in AK
Dak--how'd you learn that one? I've got the basic dash on the XLT; don't know if it'll work but will try. I've got a Scangauge II after having some fits with DEF last year but don't have any codes. I'm sitting in Continental now getting a screw removed from my Toyo tires.
Old Jul 24, 2016 | 07:50 AM
tony montana 42's Avatar
tony montana 42
Damm, I just got the message yesterday to change my fuel filters. I have ford do it. But thought about trying it myself but now I'm nervous .
Old Jul 24, 2016 | 05:46 PM
garmford's Avatar
garmford
I say do it. It's best to learn at your leisure than in an emergency. Next time I might take Golfmedic's advice and use a strap wrench along with the socket to spread the force being applied.
Russman206
Jul 7, 2017 04:03 PM
05 f250 6 inch lift
Aug 28, 2012 10:55 AM
Irish816
May 14, 2012 11:01 PM
MASTERS
May 23, 2008 08:38 AM
tjbeggs
Feb 22, 2006 09:08 PM
