Sponsored by: Real Truck
custom radio unit
Old Jul 19, 2016 | 03:37 PM
Homerunking2394's Avatar
Homerunking2394
custom radio unit
I have a 2015 super duty with no options (other than 4.30 gears), and am getting a custom stereo unit soon, will be installing myself. I know that disconnecting the battery is always good to do, but since this is a fairly new truck and there are computers etc. will i reset anything im not supposed to? will any harm be done? any tips on installation?
Old Jul 19, 2016 | 04:28 PM
RightWingNutJob's Avatar
RightWingNutJob
As far I know, the truck's computer saves any error codes and they're still there if the power goes away..
From what I recollect - the transmission's "learning curve" goes back to the default stock shift points. The truck has to re-learn how you drive it.
What kind of sound system are you putting in? Are you just changing out the OEM head unit, or going to a full-blown audiophile system with new speakers, subwoofers, separate amps, or some variation in between?
Old Jul 19, 2016 | 04:43 PM
chiefn10's Avatar
chiefn10
you really dont need to disconnect the battery. if you are putting in an aftermarket stereo and getting the wiring harness adapter, just plug it into the stock harness. there are fuses inline to protect the wiring in the vehicle. or another option is just pull the stereo fuse while you swap it out to isolate the circuit.
Old Jul 19, 2016 | 04:51 PM
Poncho450's Avatar
Poncho450
I'm not big on cutting/splicing factory wiring, so I always get the correct harnesses and install kits from Crutchfield.
Old Jul 19, 2016 | 05:37 PM
Homerunking2394
I am just replacing the headunit. I got all the harnesses and installation out from crutchfield.
Old Jul 19, 2016 | 08:05 PM
CyberJay's Avatar
CyberJay
Crutchfield is really big on their pre and post sales support. That's what they built their business on. I would take full advantage of it. Call them, IM with them, whatever you need to feel confident.
-J
Old Jul 19, 2016 | 08:50 PM
Poncho450's Avatar
Poncho450
Did a self install of a new double DIN head unit in my 2014 quite some time ago. Watch a YouTube video and go for it. These are fairly easy to take apart and access.
Another vote here for Crutchfield customer service. Just received a harness and mounting kit from them for my 2007 Mustang GT.
Buck268
2009 - 2014 F150
Oct 15, 2015 06:29 PM
TheQuackKid
Aug 19, 2014 05:17 PM
flyinryan76
Feb 10, 2011 07:10 PM
diesel2008
28
Apr 2, 2008 11:07 PM
MP1
19
Mar 18, 2005 02:31 PM
