Engine question
Old Jul 18, 2016 | 05:51 PM
smudvapor's Avatar
smudvapor
Engine question
I bought a 1990 F-250 4x4 with a 351 Auto in it. The owner before me ripped all of the emission stuff of and put headers on it then blew a head gasket. I install new heads and it runs good on the road but idles with a miss and at just a little throttle it misses really bad. The other day I drove it and the engine light came on. The exhaust is just tubes off the headers with turbo mufflers and exits out in front of the rear tires. I looked under the truck and the O2 sensor pigtail is still hanging from the harness. Do you think I should install and bung and put another 02 sensor in? If so where in the system should i put it?
Old Jul 18, 2016 | 06:23 PM
Binkowski's Avatar
Binkowski
Yes, you should install a bung and the O2 sensor in the passenger side header. It'll help. You should still pull the codes and see what they are. That always helps.
Old Aug 4, 2019 | 11:16 PM
smudvapor's Avatar
smudvapor
I do have a bung and an O2 sensor installed already. I checked the codes and there aren't any.
loseboltssinkships
15
Jun 29, 2025 11:18 AM
lamenytro
Jan 23, 2011 02:13 PM
Carson1219
Sep 4, 2007 12:46 PM
Nachin
1997 - 2003 F150
Sep 2, 2006 08:40 PM
canabait
Exhaust Systems
Feb 27, 2003 09:31 PM
