How do I install rear shocks
I know, it seems obvious, but I just got shocks for my truck. Stock 55 F250.
The top location is on a rear cross member. It seems that the shock will need spacers to keep them from rubbing.
So how do you go about installing them? Is there a spacer you guys use? Am I looking at it wrong?
I also got heavier duty shocks for the rear that have a spring on them which exasperates the problem.
Here are pictures of what I'm seeing.
Notice how the mounting hole is about 3/4 the way up the crossmember.
I bought the shocks thinking a quick and simple install
What am I missing?
What am I missing?
Did the shocks not come with mounting hardware? Double-ended bolts with spacers, lock washers, nuts, etc.? Similar to this:
By the way... the overload shock/springs aren't really a good idea for any vehicle. (I know there will be a lot of peeps arguing that *rollseyes*) The way they bolt in on your truck, and most other vehicles, was never intended to carry weight and will eventually cause issues.
I found the the bag of extra stuff. It only included two inch long spacers.
This should pull the shock out far enough, but I will need to head to the hardware store for bolts.
I would like others opinions on the shock/spring combo. I was just wanting something a little more heavy duty on the rear, but I won't be doing much with them.
Dr G
16
01-22-2020 02:11 PM
F-250 Super Duty
08-23-2013 05:38 AM
400inatruck
05-24-2012 10:31 PM
strokem
04-05-2011 10:48 PM
