Forscan trouble.
Old Jul 17, 2016 | 01:34 PM
superstroked6.0's Avatar
superstroked6.0
Forscan trouble.
Got my elm 327 adapter today. Downloaded Forscan, but when I try to connect it says no elm found please check connection. I have a single red light lit on the addapter. Any ideas.
2003 F350 6.0
Dell Insperon w/ windows 10
Old Jul 17, 2016 | 03:23 PM
FiznUKa's Avatar
FiznUKa
Are you using a laptop? Is it wifi or Bluetooth. Did you turn the key on when you try to connect to vehicle.
Old Jul 17, 2016 | 04:09 PM
superstroked6.0
Yes a laptop hooked to wifi. But the adapter is a direct usb plug in to the computer. Key is on.
Old Jul 17, 2016 | 04:34 PM
FiznUKa's Avatar
FiznUKa
Maybe open the settings menu and check to see if the COM settings is set to auto and the connection type is set to auto. If that doesn't work it's possible the adapter is bad.
Old Jul 17, 2016 | 05:36 PM
superstroked6.0
Just came in to post that I figured out I needed to change the connection type from wifi to auto. When I read this. Thanks. Now to play with it a little.
fgvanwhy
Modular V10 (6.8l)
Sep 29, 2017 07:18 PM
73fan
Feb 24, 2016 06:41 PM
tompkinsmi
2004 - 2008 F150
Aug 17, 2014 02:20 AM
stroken
Oct 26, 2010 05:34 PM
