Need help ASAP
Old Oct 25, 2010 | 01:31 PM
stroken's Avatar
stroken
Need help ASAP
After having my truck back from marty, i decided to put the 03 harness back into my truck so everything works properly instead of the 02 harness that was missing some things.
I got it all back in and everything that didnt work before works now, but when I turn the key to the "ON" posistion the engine turns over, and when i turn the key like im trying to start it it stops. Anyone with ideas? sometimes you could pull the key out and truck still run, but it never did this spinning with the key in the ON posistion.....
Its an 2003
Old Oct 25, 2010 | 09:37 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Sounds like crossed wires to me, double and triple check the wiring.
Old Oct 26, 2010 | 05:34 PM
zx250's Avatar
zx250
Of the next Riffraff East
Kenny, it sounds like you off on position on the key circuit. Like Dave said, check and recheck. Not even sure if it's possible, but check the plug in for that circuit and see if it's off. Make sure the locking tab is at the right place.
