doing u joints for first time.
Old Jul 21, 2016 | 10:29 AM
DrZoom's Avatar
DrZoom
Anthony, did you get a chance to work on your u-joints yet? Curious to know how it worked out for you.
Old Jul 21, 2016 | 10:08 PM
JRS2's Avatar
JRS2
Originally Posted by GNR22
I remove universal joints with a vise and hammer. Rest the ears of the yoke on the vice, one or two good swings with the BFH and the caps go flying across the shop. Then I use a hammer and socket to pound the new joint in. I've got a press, but I've blown enough of the faces off the end of the caps with it to not bother anymore.
Believe I usually use a variation of this method. Block of wood under end on the floor, a socket slightly smaller than the hole and give it a swing or two. Sure penetrating oil wouldn't hurt or even heat if the hammer isn't doing it's job ..... could be a couple 4 letter words in the process, but it usually works .....
waystro
Mar 23, 2013 11:41 PM
T-van
Jul 11, 2009 01:21 PM
gearhead351
Oct 10, 2007 06:28 PM
SpcLrdGregor
Nov 14, 2006 08:16 PM
exiled
2004 - 2008 F150
Sep 10, 2006 06:09 PM
