Un-clogged my oil cooler
The following users liked this post:
On the 6.7 Ford went with an external plate style.
Well it's been a week and so far I couldn't be happier with my oil cooler performance. After about 8 seconds of letting off the throttle, it will come down in temp. I've NEVER seen that as long as I've had it and now I understand how it was intended to perform.
I want to correct that the pH of my old coolant was NOT 5.5 it was 7.5. My meter wasn't calibrated at that time. I tested hardness of the old coolant at work and it was about 120. Thats not crazy hard but certainly isnt distilled water, leaving me to suspect that my issue was scale NOT metal corrosion such as aluminum oxide or ferric oxide.
Anyway, my highest delta was 9 degrees going slightly up grade with a Kubota L5030 cab tractor on my trailer on a crazy hot day. 65 mph steady unloaded yields 5 degrees and lately we've been in the upper 90's.
I just changed my oil and all was good so NO, my coolant and oil are not one huge gelatinous blob yielding the same temps by mixing through my "melted oil cooler".
I will be hauling about 5-6 tons a week until October so I will keep you guys updated.
I think it will work!!!!!
Update-cooler still doing well
Hey all,
I haven't posted in a while and thought I ought to.
my oil cooler clean-in-place with the cleaner and shop vac seems to have nailed it and my deltas are still low about 10 months later. My deltas are seriously still about 4-6 degrees as I drive unloaded and maybe up to 8 loaded. I should also add that ford 10w30 diesel oil seems to cool easier than the 15w40 (I alternate). I'm so happy with this that I can't explain it. My truck is a beast and I'd do it again if i ever see deltas above 10 degrees.
Thanks!
-Dick
Thanks!
-Dick
Great post! My EGR cooler was leaking. I removed and replaced it and the oil cooler 11 months ago. Deltas are 4-6 degrees even climbing monster grades over 10,000 feet. Deltas hit 15 or so on the way down as the oil cools slower. The new oil and egr cooler have 16,000 miles. I put an IPR coolant filter. It's a nice filter but the workmanship is crap. After making a round trip to IPR, it still leaks/drips. The screen filter is amazing. But to tell you the truth, after no less than 20 flushes before the install,the filter is always clean when I open it. Small amounts of rust. When I first started flushing, globs of junk came out for a week as I flushed, drove, flushed, etc.
If you ever do a flush, do it with the IPR filter to catch the junk. Maybe they are sending out the units without leaking valves. They get a little touchy when you mention the valves leak and advise me to check my thread sealer. I tried teflon tape, teflon paste, and nothing worked as the unit has tapered threads and the valves are non-tapered. Genius-not!
I flushed with reverse osmosis water and restore. This may sound weird, but I also flushed with Amway liquid organic cleaner after the restore. I heard people using Simple Green. I added a tablespoon of non-sudsing Amway Liquid organic cleaner left over from my Amway membership 20 years ago! Cannot tell you if it did anything. Figured it would clean anything greasy out of the system. My Ford Master Tech said to skip the VC9 flush after everything I did because the system was so clean. He said I might clog the heater cores.
I plan on changing out the ELC at 30,000 miles. It's still cheaper than an oil change!
If any of your buddies start bad mouthing your 6.0 let them know many including my van has 800,000 miles on it. The engine is not a factory crate engine. It was owned by an airport shuttle company and probably was either used or rebuilt. It's old. Has leaks here and there. But runs like an aging athlete-slow and steady.
#29
#30
Hey all,
Thanks!
-Dick
Thanks!
-Dick
Thanks!
