Front left outer axle shaft
Old Jul 22, 2016 | 12:05 AM
Bonanza35's Avatar
Bonanza35
Moose, on your XRF ball joints, did they both have the C- clip on top? I bought a new set, haven't installed yet, but both upper and lower ball joints have the C- clips. Stock one only have one, don't remember off hand which one has it. Thanks,
Chet
Old Jul 22, 2016 | 12:20 AM
derek0525's Avatar
derek0525
I have XRF ball joints on my truck also if I remember right only the bottom ones use the clip.
Old Jul 22, 2016 | 08:58 AM
brian42's Avatar
brian42
Veteran: Navy
Chet
C-clips came for both upper and lower but only used it on the lower one also (didn't fit on the upper IIRC). No problems so far.
Old Jul 22, 2016 | 09:40 PM
Bonanza35's Avatar
Bonanza35
Thanks guys, that's a relief. I haven't changed them because I didn't want to get it a part then find out it wouldn't work. Ordered from the tire Club. Time to get to work. Just has to cool down. 108 today.
Old Jul 22, 2016 | 10:16 PM
derek0525's Avatar
derek0525
That's where I got mine along with the tie rod kit they had pretty decent prices.
Old Jul 23, 2016 | 08:37 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
did you notice any mileage improvement with the Dynatrac kit?.
With the Dodge kit it's possible, especially the 2003-up, because there is no longer a disconnect between the front wheels and the transfer case and the front drive system turns all the time whether 4x4 is selected or not.
With the Ford, the selectable hubs allow free-spin already when "turned-out". There is no appreciable drag difference between the wheel bearing styles so all a person is doing when buying either brand of fixed spindle kit (Dynatrac or Spyntec) is getting rid of the inferior hub bearing assembly and the oft-problematic stock selectable locking hubs that don't always disengage right away or unless they're tapped with a hammer.
Old Jul 29, 2016 | 06:27 AM
barko4's Avatar
barko4
Okay, I've just about finished it up. All I have left is to bleed the brakes. Thanks for all the help!
samr.820
Oct 16, 2018 01:47 PM
EXtraEX
Mar 27, 2015 04:29 PM
MixWizard
Feb 9, 2014 09:01 AM
64deville
Mar 28, 2012 10:24 PM
dartol
Offroad & 4x4
Sep 26, 2000 02:40 PM
