Grey smoke? Update
Old Jul 15, 2016 | 09:43 PM
firedaniel's Avatar
firedaniel
Grey smoke? Update
Noticed today a big puff of smoke when I started it but didnt think much of it. When driving I noticed it is puffing a grey smoke smells like unburnt diesel. My EGR is already deleted and no coolant is leaking. I am thinking injector issue. The truck drives and runs just fine with no issues. Am I thinking right I need to get a contribution test and see which one is acting up? Truck is mostly stock with 250k miles on it.
Also what is the best injectors to put in it?
Thanks
DW
Old Jul 16, 2016 | 08:08 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you end up having to replace the injectors, Motorcraft is the way to go.
Sure, your can have it rebuilt, but it's nowhere near the quality of Motorcraft.
You should monitor your FICM voltages and see what they're doing. If the FICM main drops below 45 volts (according to Ford) it's time to repair the FICM. For me, the FICM dropping below 47 volts is warning enough for me.
Old Jul 16, 2016 | 08:37 AM
firedaniel's Avatar
firedaniel
I use a scan gauge to monitor everything and the ficm is fine. Truck actually runs fine. Just the smoke.
Old Jul 16, 2016 | 10:00 AM
BLADE35's Avatar
BLADE35
COMPRESSION/INJECTOR BUBBLE TEST
Compression Bubble Test - DTS Articles - Articles - Articles - DTS
Old Jul 16, 2016 | 11:46 AM
firedaniel's Avatar
firedaniel
Well I don't know what to do now... Stopped by the dealer and had a contribution test run and they came back and said injectors are fine it's the EGR is blown. I have a EGR that's welded shut on each end and a tune that turns the valve off. I'm a bit at a loss. I could delete the EGR I guess since I already have the tune. Any thoughts?
Old Jul 16, 2016 | 12:04 PM
BLADE35's Avatar
BLADE35
sometimes things get missed even at the dealer and that's the cool thing of this forum setting so many eyes looking at it diffrently
Check turbo system
any dtc
Old Jul 16, 2016 | 12:56 PM
firedaniel's Avatar
firedaniel
No DTC. I wouldn't even know it if I didn't see the smoke. It's black under power and grey or white at idle.
The EGR pipe welded on both ends what is the odd of it failing? Oil cooler numbers look perfect.
Turbo cause that smoke?
Old Jul 16, 2016 | 01:28 PM
Don Naslund's Avatar
Don Naslund
You can pull the EGR and see if it is wet inside. Otherwise, I would go with the injector issue. There should be a contribution fault though if it is an injector issue.
Old Jul 16, 2016 | 03:19 PM
firedaniel's Avatar
firedaniel
There is no injector code or any other code.
I'll pull the EGR valve and have a look I i guess.
Old Jul 16, 2016 | 06:24 PM
tfunk88's Avatar
tfunk88
CAC boots torn? It sounds like you're not getting the expected air into the engine that the FICM is fueling for
Old Jul 16, 2016 | 07:22 PM
BLADE35's Avatar
BLADE35
your smoke symtoms are exact same as mine were with a failed inject in my truck
Black WOT and Grey/white under idle light throttle
Many different things could cause it I just find it weird coincidence the smoke condition is exact
a Bubble test would confirm a leaking inject and its easy enough to do One would think a contribute test would have showed but
Old Jul 16, 2016 | 08:43 PM
firedaniel's Avatar
firedaniel
I still have power so I don't think it's cac boot but will check when I tear into it. I'm wondering if they did the balance test like I said to do. They said they did but I figured my injectors were getting weak with 250k miles on it. I guess I could pop a EGR delete kit in and put a set of injectors in it. Maybe it's time. Come to think of It did have some stiction when cold before switching to synthetic. But power seems fine just smoking....
Old Jul 17, 2016 | 12:52 PM
firedaniel's Avatar
firedaniel
I wonder if I should do arp studs while I'm down that far
Old Jul 17, 2016 | 01:01 PM
Don Naslund
A stud job requires that the heads come off. A big job but not too difficult if you have the tools. You don't show symptoms requiring you to go that far into the engine right now. I think that you have an injector problem only.
Old Jul 17, 2016 | 06:01 PM
firedaniel's Avatar
firedaniel
Can I unplug injectors while running and see when it stops smoking? Would that be a way to identify which one is the problem?
